0 Members and 92 Guests are viewing this topic.
isim
@TinselKoala
R=Rho*l/S   with Rho=1.7*E-8 Ohm m,  l the lenght in meter, S the surface in m²
3cm of Cu wire solded (inserted), on one of the cutted  leg of your air coil, may do the work.
you can even etalon the R with a DC current and a meter.
Don't forget to put 2 perpendiculaires wire on each end of th R, the have 2 goods connections points.
I don't have time this evening, but if you wont I will send you a drawing tomorow if this little schema don't make sens.
One leg: --------------
//  : the break in the leg
X  : solder
Wire who make resistor R : ____________
And |1 and |2 the 2 connections points well define
                     _____________
-----------------X------//-------X-------- Wounded coil
                      |1                  |2         |                 |
------------------------------------------ Wounded coil
R=0.02 ohm is enough, at 10A you get 0.2V with P=0.02W...
Input for that run=
Straight DC, 11.95 V @ 0.58 A = 6.93 Watts
Output by scope measurement=
Vrms x Irms x cos72 =
26.51 V x 3.82 A x 0.309 = 31.3 Watts !!
COP = Out/In = 31.3/6.93 = 4.5
:P
ETA: Phase angle from Lissajous figure:
sin ⁻¹(25.6÷27) = 71.47
Quote from: isim on July 26, 2014, 07:21:42 PM
@TinselKoala
X  : solder
                     _____________
                      |1                  |2         |                 |
Sure, I got it, but I think I'm already ahead of you. See above... I was able to use my 0.25 ohm Ohmite stack without as much disruption and heating as I expected, and I think I have valid results now. I'll try your suggestion anyway, as well, if I have time. Thanks for working on this! Please review my results above and let me know what you think. Why am I not seeing a full 90 degrees phase shift, or at least 87?
MarkE
Quote from: TinselKoala on July 26, 2014, 05:27:42 PM
The microQEG primary coil wire is about 171 cm of solid copper wire with diameter 1.59 mm. The coil is wound on a 3.25 inch OD cardboard form, 6 turns "Tesla BiFilar" closewound spaced by insulation, with 3 inch leadin legs. My inductance meter reads it between 4 and 5 microHenry and calculations seem to indicate it is right about 4.25 uH.
Unfortunately I am up against the limitations of my kit, I fear. I can't easily measure fractional-ohm resistances precisely so making a custom shunt for 0.01 ohms would be a matter of guesswork.
The DC resistance of that winding is about 15mOhms.  It is enough to use directly with a scope that has 20mV/div sensitivity to look at a 7Arms signal.
So what's wrong now with just using the Ohmite 0.25 ohm stack as I have used it? It does produce some droop in the voltage but that is acceptable at this point, since it doesn't overheat very rapidly like I thought it would based on earlier experiments.
Meanwhile, here's another video update, showing what the QEG people have never, to my knowledge, been able to show from their constructions: running a motor from the output of the microQEG, with full and efficient RPM control.
http://www.youtube.com/watch?v=JkXrhRqlQE4
Those slackers! If they can't run a motor off their output, how are they ever going to get to self-looping? Are they tearing their hair (what's left of it) out right now? Or, perhaps they are working feverishly day and night, getting "resonance in the power band" over and over, reading those FAQs on be-do, yet flicking the switch and watching their baby die, deader than a doorknob, each and every time they try it.
