0 Members and 76 Guests are viewing this topic.
synchro1
I think the "Shock conditioning" of the bifilar primary may involve a shock through the inductor, nor in close adjacency. I've spoken of the "Shock charging of the bifilar"  and the subsequent ringing. The spontaneous rising of Ohmic resistance in the coil signals increasing resonance from the shock, a sign the charging event occurred.
Remember that the bifilar has it's own resonant frequency between it's natural inductance and high internal self capacitance. A Hi voltage potential is generated between the windings of the bifilar, in self resonance, that is many thousands of times greater then the voltage produced between the wraps of the single wire solenoid. This charge needs to be induced in the bifilar coil from shocking! We can shock a single wire coil with much lower resonant tank capacity then the bifilar, and get nothing in return. It may take several trys!
By the way, a dead fly showed up in my Burgesa!
synchro1
Ferro-resonance was demonstrated by Whoppy, who tapped an iron core and got output spikes on his scope. Iron's kind of a Piezo crystal. Shocking a bifilar coil around a ferrite core generates electrical feedback. The QEG may generate power this way. Shock charging a bifilar around a hi perm ferrite core will yield ferro resonance. An air core coil can't generate this kind of resonance.
Farmhand
Well I set up a small spiral coil 1mm wire and 11 turns I think, it's 18 uH and with only 1 Watt or so input, (12 volts at 80 mA ) I get
about 90 volt DC pulsations which excite the receptor coil when tuned to almost 600 volts point to point.  :) Sine wave. Looks like
about 550 mA of current in the receptor tank. I'll set up some loads tomorrow. Neaten it up. I was surprised how well the spiral
coupled with the bifilar "solenoids" at some inches distance. Power input is tiny 1 Watt, with all that activity.  8) Video clip
shows the receptor wave forms of voltage and current but it's hard to see, quality is bad (using stills camera).
EDIT: Yeah so no load is about 180 volts RMS and about 550 mA RMS in the receptor tank but i can't work out the phase and no load.
Video clip (bit rough and image quality isn;t good either)
https://www.youtube.com/watch?v=kN-8wNK3vv0
First image is the drain wave form on the primary.
Second image just shows the set up, the neon is between the center of the bifilar and one end.
Third image is how the setup was oriented for the video.
Oh I forgot, I got no core to condition.
Shanti
QuoteFerro-resonance was demonstrated by Whoppy, who tapped an iron core and got output spikes on his scope. Iron's kind of a Piezo crystal. Shocking a bifilar coil around a ferrite core generates electrical feedback. The QEG may generate power this way. Shock charging a bifilar around a hi perm ferrite core will yield ferro resonance. An air core coil can't generate this kind of resonance.
Well it's just magnetostriction at work. You don't need a bifilar coil for that...
Edit:
E.g. if you loosely wind a coil around a core, and tap the core, so that it starts to oscillate mechanically (acoustic wave inside the core) you can very good see this mechanical oscillation with a pickup coil.
synchro1
Quote from: Shanti on July 29, 2014, 12:49:15 PM
Edit:
The bifilar coils throws a larger spark across a greater spark gap distance than a single wire coil with the same Joules of discharge. Tinselkoala demonstrates just that "Larger spark" feature in his bifilar comparison video. The speed and magnitude of the magnetic field collapse determines the back spike voltage. This is how TK's reaching 500 volts in his capacitor.
