0 Members and 74 Guests are viewing this topic.
isim
@TenselKoala
"I suppose you are talking about the loopstick  ..... "
Yes, may be I will do a simulation. These tools are extraordinary. No electric shock or what so ever else...  :D
Thanks
http://www.youtube.com/watch?v=pSoZSXX4TJM
8)
OK, I took one apart. The cotton wire outer insulation didn't hold up too well but maybe I can reuse the wire for something.   :-\
It is 15 or 16 strand Litz. The strands are so fine I can barely see them even with 3x magnifying glasses, hence the uncertain count. Cotton wrap covering. It is wound in two groups of 260 turns each, on a phenolic tube former that is 7mm outside diameter. The groups are about 9 mm long and are separated by a gap of 2-3 mm. The core is a ferrite rod 1/4 inch (6mm) diameter x 28 mm long with a brass #4-40 threaded rod in one end.
synchro1
"When alternating current passes through a component that contains reactance, energy is alternately stored in, and released from, a magnetic field or an electric field.  In the case of a magnetic field, the reactance is inductive.  In the case of an electric field, the reactance is capacitive.  Inductive reactance is assigned positive imaginary number values.  Capacitive reactance is assigned negative imaginary-number values".
"Reactance is a form of opposition that electronic components exhibit to the passage of alternating current because of capacitance or inductance".
The opposition to A.C. is assigned an imaginary number value. A Negative Micro Henry is a measure of opposition to A.C.
Quote from: synchro1 on July 30, 2014, 09:53:09 AM
When alternating current passes through a component that contains reactance, energy is alternately stored in, and released from, a magnetic field or an electric field.  In the case of a magnetic field, the reactance is inductive.  In the case of an electric field, the reactance is capacitive.  Inductive reactance is assigned positive imaginary number[/u] values.  Capacitive reactance is assigned negative imaginary-number values.
Reactance, denoted X, is a form of opposition that electronic components exhibit to the passage of alternating current[/u] (alternating current) because of capacitance or inductance.
Careful, you are about to choke on all that copy-pasta.
synchro1
You're putting along fine then a spring pokes out and jams the works up. Look, now another Windmill tilting on the Myth Bust the biflar crusade!
Look, the series bifilar has zero reactance unlike the single wrap that produces a directional field. The cancelled fields don't exert opposition forces like the field that produces Negative Microhenries in the single wrap. This is a measure of reactance. The series biflar does not impede A.C. like the single wrap with Negative Micro Henry reactance value. This value generates waste heat! That's the major difference between these types of coils!
This is a very real and important difference!
