0 Members and 85 Guests are viewing this topic.
Quote from: Farmhand on August 01, 2014, 09:09:01 PM
Please Synchro do some research, here's a good link below. Ignore the "beginners" label to the page the info is very good.
http://sound.westhost.com/xfmr.htm
Snippet
Why should he ignore the beginner's label? If the shoe fits, he can wear it proudly.
A decade of constructing confirmatory demonstrations can be completely invalidated by a single proper TRUE EXPERIMENT.
Meanwhile... here it is August 2 almost and there has been no word from Pennsylvania, no word from the UK, no word from Florida, not from Taiwan or South Africa, not from Morocco or Germany..... but Jamie was only "hours away from self running" weeks ago, and many dollars in donations have been made since then to help get the Philadelphia Prototype to run by the end of July..... and all I hear is the sound of crickets chirping.
Hey, FIX THE WORLD QEG BUILDERS: your world is broken and you are helping to keep it broken by your cynical fraudulent campaign, which sucks up money and other human resources that would be much better spent doing other things.
synchro1
ISW 9674GR-600HZ 12vdc 160-328ft EL
Continuous, 600HZ, 12vdc input, 120VAC output, runs 160-328ft EL, Dimensions: 2 7/8" x 5 1/8" x 1 3/4", Weight: 2lb 3oz. Use at least 2.1 amp power supply when running 200+ feet. Made in USA. Our Price: $89.00
This electroluminescent inverter produces a 120 volt AC current at 600 hertz. This is pretty close to the signal Gotoluc uses in his toroid 2 experiment.
Large diametric tube magnets wrapped in trifilar coils, one series bifilar to run the hi frequency current through and a third for output to diode and capacitor, should generate the same kind of free energy Gotoluc's bifilar toroid does. These magnet generators could be wired in series.
The frequency is is magnifying the field, resulting in the increased reactive current. The field fluctuation and intensity oscillates the output core magnet through the bifilar and generates a current in the output winding free of charge, if the current goes to run the light panel.
Farmhand
Here's a scope capture below of the "HV tank" in the set up I had going last night, the setup was,
1) the 18 uH spiral coil with 20 nF across the single mosfet switch, which produces DC "lumps".
2) the coupled tank circuit which is 320 uH - 56 turns and the variable tuning capacitor 40 pF to 1300 pF.
3) the output coil of about 24 uH about 16 turns (wound next to the tank coil)with a tuning inductor with
moveable core (2 to 18 uH) and 20 nF across it all with a FR FWBR and 6.8 uF output cap.
This setup pulled between 80 mA and 200 mA from the 12.5 volt supply, with different loads and tuning.
Tank phase changed only slightly.
I was able to power a small disk drive motor with 10.5 volts and 80 mA from the output or light LED's.
The tank coil voltage is high enough at full tune to make neon's held in the hand near the coil glow. Fluro's can be lit by
touching them to one tank conductor ect.
With this arrangement if the loads are right for the output and the tank is tuned the setup draws more power to
supply the load while maintaining a quite high tank activity.
I've dismantled it to try halving the tank and output coil resistances as well as increase their capacitance.
Yellow trace is the tank voltage. 199 Volts RMS sine wave
Blue trace is the voltage sensed across a 5 Watt 0.1 Ohm resistor. 0.121 v RMS / 0.1 Ohms = 1.2 Amps.
Phase is showing real power being consumed.
Or could the phase be a result of the fact that the tank coil is a serial connected bifilar "wound" coil with about 400 pF capacitance
between the windings ?
The output coil is also serial connected bifilar "wound". But it's only small.
Maybe a significant amount of energy is staying in the coil and not oscillating between the external cap and the coil but also
between the coils own capacitance and the coils inductance ?
PCB
Quote from: TinselKoala on August 01, 2014, 10:30:56 PM
My sources tell me that Jamie has in fact been successful and has managed to close the loop and create a self runner. Unfortunately in building the QEG he has run foul of QED and has apparently winked out of existence, so I do not think we will be hearing any thing further from him. I'm told that Hopeless Girl is devastated by the loss of her step father and more so by the loss of the knowledge he took with him. Oh well!
