0 Members and 88 Guests are viewing this topic.
Quote from: Farmhand on August 02, 2014, 09:50:42 AM
Some should get a laugh from the video clip below. Might need to turn up the volume to
hear the motor generator hit resonance power level, it's quiet.
I wrote a bit of a description  ;)
Central Queensland Has Resonance YaY. Here's a short clip showing the
motor generator light up the lights when the magic resonance is achieved.
That's 2 motors one driving a generator and some lights from energy tapped
out of the resonant tank.  :o
Resonant Tank Tapping with Resonance ! Tesla's Bad Dream circuit.  ;)
https://www.youtube.com/watch?v=vqqeCtdHyUA
Not all rosy though there is a cost.
Well Done ! It looks like you are only Minutes Away from Self Running!
Now you can get that little mo-gen setup to charge up a big bank of capacitors, and when it's charged, you can swap out your main power supply and put in the capacitor bank as PS and demonstrate your apparatus running on its own power, that came from itself! And nobody, no where, will be able to argue with you.
Farmhand
Quote from: TinselKoala on August 02, 2014, 07:21:02 AM
http://www.youtube.com/watch?v=djhi8hf47Gg
Thumbs up!
Yeah this guy makes some good points and his QEG looks real nice "picture perfect". I'm not sure I want to see his replication of
the Rattatooee Transvestiter though.  :D
Tinsel, I'm afraid I'll have to defer the self running for a while yet, a set up with no AC 50/60 Hz output is not much use, so I
found a multi pole AC permanent magnet generator that will output 240 volts AC at 50/60 Hz if I can gear it right.
Once I get a 50 Hz 240 volt generator going I can run the house from it and sell power back to the power company.
I don't need it to self run if I can run it from a battery charged by solar panels, so the self running is on the back burner, sorry to all my investors, hold tight, the longer we wait the worse the world will get, so then we can fix it more with a bit of hope.
Cheers
Pirate88179
Quote from: Farmhand on August 02, 2014, 11:04:21 PM
Cheers
Farmhand:
But what about all of those folks just waiting, check book in hand, to donate to you?  What will they do?  They will be very disappointed if you do not take their money.  You might want to re-think this.
Farmhand
Actually Pirate, I still need to experiment with the lower inductance - higher capacitance tank, lower voltage more current.
Not sure it will work as well as far as output voltage goes but maybe better efficiency since the resistance will be halved in the coil,
and the radiative and distributed capacitance losses will be less. I can run the primary coil from up to 100 volts, the circuit 15v.
bit the capacitor is still the same. I'll need to choose good capacitors and employ a tuning coil in the tank with a fixed capacitance.
That will save space as well as be less sensitive, easier to tune, ( the variable capacitor is very touchy ). When the tank voltage is
very high the presence of the body and other things become an issue.
I intend now to scrap the mechanical AC 240 volt generator idea as too lossy.
Now I intend to "stiffen" the output with a bigger good quality capacitor and simply design an inverter circuit to run from
the voltage on that, I'll design it to run from 5 volts but tolerate more and output 120<0>120 with a 14 volt winding or something.
Maybe 60<0>60 might be better. I might already have one.
There is a design for a relay that outputs a sine wave efficiently but I'm not keen on that (noise) I'll use push pull mosfets, maybe uC.
I'm interested in setting up a small exhibit showing energy collection - power generation - transformation - transmission and then
the down transformation and translation devices and various loads, which can all be measured, then the effect of the end use
can be seen in the generator and so forth.
The little AC motor is from a microwave turntable and has a single coil with upper and lower "pole plates" which bend around the
coil and make 8 - N-S poles, 4 cycles per revolution, slow motor, maybe mini wind turbine. It might need rewinding with better wire.
synchro1
I maintain that: Ferrite cores transform A.C current, and Magnet cores multiply A.C. current.
Tinsel Koala mentioned "Standing wave resonance" in his QEG. How do these standing waves differ from the longitudinal magnet wave?
The magnet core multiplier is a trifilar solinoid with same core diameter diametric tube magnets in the bore hole. A high frequency sign wave oscillation sent through the series bifilar coil, made from the trifilar coil, at resonance,  should deliver equal power through the 3rd coil, with no rise in input, through reactive flux transfer, not induction.
A magnet placed next to a live wire carrying A.C. current has no effect on the current. However, I maintain the inverse is not true; "The magnet's effected by the A.C. current"!
That's the underlying principle that delivered Mega OU from Floyd Sweet's "Vacuum Triode Amplifier". My "Magnet Core Multiplier" is practically identical to Floyd's initial design, and Bedini's first coil approach. Then Bedini seperated and redistributed the inductance of the output coil with a cross pattern. Note that both VTA output and input coils are series bifilar in the schematic below:
