0 Members and 90 Guests are viewing this topic.
Farmhand
Quote from: TinselKoala on August 05, 2014, 01:53:25 AM
Hah.... since you have all that resonance, I suppose I should post this here just for the record. I'm starting to play in earnest with my own "yolks" and the uQEG as driver.   ;)
http://www.youtube.com/watch?v=OadJX-BVUow
Wow cool vid, with flames. I like it !  8) What are your plans as far as tanks and so forth go ?
My setup is restricted input, I can get into the driver circuit about .5 amps at 14 volts without widening the driving pulses or
using a regulator for the pulse generator and utilizing a higher voltage supply.
I want to stick with a rough "analogue" of the QEG setup elements.
1) A driver device (QEG DC motor) my circuit driver board with spiral.
2) A HV tank.
3) A second LV coupled winding. (output coil).
4) A translating device to produce whatever character of power is desired ie, HF AC - LF AC - DC.
And I might also use the output to charge a capacitor and dump it through some stuff. for fun.
P.S. Tinsel, I think you just did a rapid "conditioning" of your core. Should be set to go now. watch out for that quantum vortex
funnel though. The TV yolk will tempt it out due to it's shape.  ;) Be careful which way you point that thing or you might get more
cheese than you can deal with.  :D
Farmhand
I notice I can do the same thing with this setup as with others I've had. Depending on how the HV tank is tuned when a load is connected to the output the input either stays the same, or it increases or it can decrease as well, depending on tuning.
I have the end of the tank closest to the Driver spiral grounded, as well as the end of the output closest to the HV tank is
grounded too.
With a motor connected to the DC output the highest speed "tune" a bit different to the highest torque "tune".
This can demonstrate the reduced input under load BS as well as many other fallacies, with the help of you learned guys I might
be able to get some meaningful measurements. So far the only thing I trust is the tank Voltage Measurements and the DC input
power measurements.
ACG
Got a hit on hopegirl activity.
So we know she is still making post at least to other people's facebook.
https://www.facebook.com/media/set/?set=a.744719685584790.1073741831.680750941981665&type=1
"Here are some photos from the team's latest stop in Spain where an agreement was made with a research group to cooperate on a transverter / energy savings / gateway to self-running device."
Good old bait and switch.  The trick this time is to associate the images of prior existing power and motor control systems with that of qeg as if one had anything to do with the other.  Notice hopegirl said 0 about her end of July self-running.  Come to think of it, what is the world with Kevin Blundell from Canada?  He upoaded a video for funding and has been silent for 2 months.  I will wager 1 Torelco core that hopegirl puts this Spain info in her next eventual blog release.  Any takers?
I remember many people in all the forums chanting "wait and see" so I coined the term the "wait see" virus.  Where are all those wait see zombies?
Something MileHigh would appreciate:
You have waited and you have seen.
Pockets of your, fleece the world has picked clean.
Farmhand
Here's a rough drawing (bottom section of top picture) to show the setup and scope placement points "A", "B", "C", "D" and "G" for
the scope grounds, these are to measure the power in the output tank Point "C" and "D" and the transformer primary Point "A" and
"B". I've just got some 470 uF capacitors there for now just to see the GDT's go...pop.....pop....pop..... :)
Input is restricted to 7 Watts Max for the time being.
Also is a picture of the actual output setup to drive the yolk transformer, when I want to use it i'll solder the primary
to the 0.1 Ohm resistor.
P.S. Am I allowed to add up all the VARs from all the tanks ? And the yolk primary power and add that to the power output ? And
add those values to the power developed when the capacitors discharge "added up over time and averaged" ? Then with all that
added together compare that to the 7 Watts input power ? To get an over unity value in VARs and Watts both together from all
the power points I can measure. Anything I missed ?  :P
I would almost bet I can get an oscillating power VAR value close to what Rattatooee gets from his setup and I think I can do it
with less than 20 Watts input. Can I count an antenna output as output ?
Can I use lights and devices rated values as an output value ?
ACG
Just after I posted about hopegirl being spotted she puts up a video!!
https://www.youtube.com/watch?v=fzSlQnpiCAs
I am so anxious on the edge of my seat I cannot even contain myself  ;D
Will return.
Back!  ROTFLMAO and spilling every container of liquid within my arms reach!  I cannot believe my eyes and ears.  I cannot believe some guy on the camera tells us what a transistor is and that they switch on and off.  "If you use the right size resistors you can create an inverter"  Right size resistors?  There are no words there are no words.  Who does he think his intended viewers are, a group of 5th graders?  And thanks to the pointless music overlay I can catch but a few words James says.
I found the angle now.  Its a promotional video linking Torelco and a relatively new website on the qeg front that will be selling qeg parts and kits.  Its all coming clear.  Over priced $129 solid state relay boards galore.
http://teslaenergysolutionsllc.com/
Notice not one peep about the fundraiser, about the self-running demonstration at said fundraiser, and about self-running period.  Nothing.  But had time to mention Noah and the arc.  I told everyone months about her delusions of grandeur.  Now officially confirmed.
In narrative order and now on #6:
1. Output of 240v 42 amps 60hz to be easily connected to your house (from manual 03-25-2014 http://hopegirl2012.files.wordpress.com/2014/03/qeg-user-manual-3-25-14.pdf).
2. Output of 2000v 5 amps 400hz (from Taiwan interviews starting @4:40 http://www.youtube.com/watch?v=atLN-mkmqBE notice James said "if")
3. Output of 1400v at lower amps yet 200hz, and may need an aerial? (Morocco May 2014)
4. Output to be supplemented with a Markov coil + transverter to draw power from reactivity of the primary coil (United Kingdom June 2014 http://hopegirl2012.wordpress.com/2014/05/25/qeg-3rd-phase-development-self-running/).
5. UK No Go.  Return to Pennsylvania prototype.  Now classified as Research and Development.  Self runner to be completed in a month (July 4, 2014 https://twitter.com/hopegirl587/status/485162445795635200)
6. Use of a 34ft antenna to the qeg. (August 5, 2014 https://www.youtube.com/watch?v=fzSlQnpiCAs)
