0 Members and 52 Guests are viewing this topic.
Well, there are easier things to do than chopping up a bunch of transformer-grade steel laminations, but I suppose an industrial chipper could probably do it. Personally I think the cores should be killed with fire: the cores melted down, cast into mixed iron-copper ingots and then made into finger rings (or nose rings as appropriate) and distributed to all the believers, like Canadian engineer's rings, to remind them always of their folly.
TK:
Yes indeed about voltage being relative.  That's why the daredevils that fix live high-voltage transmission lines "bounce" along with the line.
It's either that or burnt toast.
Just a few comments about Jame's (Mr. 17 Year Cicada) posting:
http://be-do.com/index.php/en/forum/manuals-documents-and-tutorials/542-qeg-instructions-for-engineers
QuoteWe saw that most of the engineers (including myself) were expecting to make some tweaks, do some rewiring, try things like: resonate both windings, add capacitance in the secondary, move the load around, series or parallel?, add this transverter, or that inverter, shunt, transformer, rheostat, isolate the load so resonance is not disturbed, etc.
That sounds like Electronics Romper Room to me.  I don't think any real engineers would be doing that.  Nor do I believe that Jamie is an engineer.  I believe that he is a bench technician.
QuoteWith the generator built to the original configuration, there is up to 30 kVAR (peak-to-peak) reactive power available in the primary windings that could be converted to possibly 20 kilowatts (RMS) and used to power normal loads.
The "VARS to real power" nonsense again.  And the "RMS" gaffe again!!!!  Dyslexic bench technicians of the world desolder!
QuoteBut using the secondary (in the original configuration) to provide enough power to self-loop has been a bit of a mystery, since we need 700 to 900 Watts (RMS) to run the motor, and to get that much output from the machine, we would be drawing 900 to 1100 Watts from the wall outlet. That leaves us about 200 watts shy for COP of 1. This has been about the same with all the machines we built including Pennsylvania.
We have been telling you this since the beginning you fool!  But truly Jamie you have known this since the beginning also.  Perhaps one day that will come out in court.
QuoteThis endeavor has been a technical puzzle for us. Any information we received from websites, technical documents, individuals etc., had to be tested and verified, reduced, converted or extracted to see if it would be applicable to the QEG prototype. We got a lot of useless information, some information missing important details, and even some deliberate misdirection as noted in the previous section. We also gathered quite a bit of good information and history, and made many wonderful personal connections. One of those connections was with Tesla Energy Solutions LLC, who brought us the most useful information so far, and much needed support.
It's been a puzzle?  What the hell do you mean it has been a puzzle?  We will remind you for the 500th time that you and hope-i-don't-go-to-jail girl clearly stated that IT WORKS, ALL THAT YOU HAVE TO DO IS DOWNLOAD THE PLANS AND BUILD IT.
You Be-Do forum scared and demoralized zombies:  Start speaking your true feelings.  We don't live in a society where thoughtcrime is a crime.  Your forum is creepy and horrible and it's time you did something about it.
QuoteOur path, from the beginning, has been focused on duplicating the self-looping machine we've all seen in the "WITTS 40kW fuelless generator" video.
For anyone that still has any doubt, the WITTS video is a FAKE.
QuoteThat is because after the core is conditioned
Don't make me laugh with that nonsensical idiocy talk about "conditioning the core."  You are talking crap to play to your audience, the ones with money to burn.
