0 Members and 85 Guests are viewing this topic.
Farmhand
OK I showed in my shots that I can use an output coil to power a resistive load with 1 watt while the primary shows 6 Watts of
"in Phase" power and the HV tank shows hundreds of VAR, while the input is only about 2.5 to 3 Watts.
The only thing that matters is the 1 Watt out and the 3 Watts in.
Forget about quoting VAR values and just show the output power and input power.
And the "antenna", if I disconnect my antenna I cannot get enough ground line current to light up the neons. A clear case of
the antenna capacitance displacement currents causes ground line currents. The effect is marked. Clear as can be.
QuoteThe point is, we believe the secondary is intended to provide the output.
So people are giving money to a Joe Blow so he can "investigate" a useless hunk of metal and wire to see if his beliefs are true?  More self-incriminating talk Jamie - see you in jail!
QuoteWhat is the significance of specifying 400Hz / 200Hz generator frequency? WITTS says that M21 type steel should be used because its self-resonant frequency is right around 400Hz.
I am not aware of the concept of "the self-resonance of a certain type of steel."  I don't think he is talking about the mechanical resonance of a bar of steel of certain dimensions, mass, and stiffness.  As far as I am concerned that is just junk pseudoscience nonsensical talk.  It's outrageous to think a group of a dozen or so grown men can be in a room and talk like that.
Quoteis the same as the steel's self-resonant frequency, we will have additional piezoelectric effect, creating additional voltage in the primary.
The piezoelectric effect is as dead as a doornail when it comes to producing energy from nowhere.  More nonsense.
QuoteIf any QEG builder out there has access to a steel testing facility, perhaps they would consider having their core tested to determine what the actual self-resonant frequency is.
Even though it's all nonsense, if Jamie, the artist formerly known as a bench technician, had any brains, he would put a very tiny microphone on his core and whack it with a ball peen hammer.
I can't be bothered and I am too tired to go any further.  Perhaps another day.
For anyone sitting on the fence:  Do not spend a single cent.
For the Be-Doers:  "10 Posts that Shook the World."
Take a solid chunk of metal, suspend it with a rope and strike it with a hammer. Hear that nice pure ringing, high pitch, goes on for a while? Now take a bunch of laminations, bundle them together and secure with through-bolts. Repeat steps 1 and 2 above. What do you hear?
Clunk. Or maybe, Thud. Or, in the best case... Thwack, perhaps.  You for sure won't hear a "core resonance" because the laminations make very effective acoustic-- read "mechanical resonance" -- dampers.
The be-do FAQs:
http://be-do.com/index.php/en/faq
Image below taken just now.
I'll donate a hundred dollars but only after I see HopeGirl start up a QEG with a crank mechanism.
On the issue of Torelco's involvement: What if it were discovered that part of the sales price of a QEG core from Torelco, went into the pockets of FTW/Robitaille family? That is, what if there really was some kind of formal business arrangement between Torelco and FTW? How would that affect Torelco's liability situation with respect to the false claims made by FTW and the Robitailles?
