0 Members and 94 Guests are viewing this topic.
Void
Quote from: Farmhand on August 26, 2014, 10:46:17 PM
Void, that's not really the way it all played out. The antenna is only recent, the tank consists of capacitors across the secondary
coils, the antenna and ground connection were only used and shown in the "Barn video". The antenna and ground only form a
portion of the tank circuit (just as I showed).  They were showing light globe loads without an antenna or ground connection in the
other countries. The antenna demonstration showed him powering a bulb from between the HV tank and the ground connection
easily a light can be lit using a ground return in such a setup and without tracing the connections we have no way to tell actually
how it was wired.
The claim is that they can convert the tank VAR value into real output power continuously without using more input, and
in fact self run the device, they claimed to already have done that but lied.
A pattern of lying has emerged.
The parametric excitation is likely only a part of the story, there would be residual magnetism in the rotor and also as soon as
some tank activity starts then it would be self exciting in my opinion  the currents in the tank would cause loading on the rotor,
and that is obvious when resonance is achieved because of the loading down sound of the rotor.  An effect of induced
magnetism in the rotor maybe. The rotor see significant load.
Fact is the input power to the DC drive motor is what is pumping the tank up. Output has never even come close to exceeding
input.
Fact is they are lying to get donations from people, raising money by deception is fraud.
Sounds like you've come to defend them and their actions Void. You asked me what I was trying to achieve here, I think it's fair
I ask you the same.
What is it you are trying to achieve here Void ?
Ha ha, Farmhand. Relax mate.  :)  I have no purpose posting here beyond just giving my opinion on this topic.
As I said, I am going to wait and see what they can come up with before I try to draw any definite conclusions about this device.
Can you point me to exactly where they claimed that they already had a self runner?
I was aware that the hookup of the antenna and ground wire was done recently, but that is what they are
saying now is what they believe necessary to  'condition the core' over time, to achieve over unity.
It is possible that the exciter tank coil is picking up the magnetic field from the drive motor, and using that as
some excitation for the toroid coils, but in some of the demos the device appears to be delivering
about at least a couple of hundred watts to the light bulb loads. That would seem to be a lot of power
to be drawing off the electric motor's surrounding magnetic field. Your statement that the rotor is definitely magnetized
appears to be speculation only. If you said that you think that could be a possibility, that seems reasonable
to me as a possibility. However, to state this as if it is absolute fact rather than speculation, does not really seem
reasonable. The rotor might become magnetized somewhat, but a person would have to test the rotor for magnetization
after it has been in use for a while to say one way or the other with certainty if it is becoming magnetized, and how much
it is magnetized if it is becoming magnetized.
All the best...
ACG
Reluctance Generator:
72 references to usages and improvements of switched reluctance generators: http://www.scirp.org/journal/PaperInformation.aspx?PaperID=25035#.U6m_nijFKSo
http://bib.convdocs.org/v11950/?download=2
http://www.ijcaonline.org/journal/number3/pxc387189.pdf
http://www.freepatentsonline.com/7394229.pdf
http://www.scirp.org/journal/PaperDownload.aspx?paperID=4036
Nothing new.  The core is initially energized to build a remnant magnetism in the steel if one is not present or naturally decays after periods of time of non usage.  Therein lies the genuine function of the mythical magical "quantum exciter coil".  Had the rotor been made of wood, that would indeed be very interesting.
I just might have to break out another can of "wait see" virus prevention.  Last can damn there took me out.
isim
@Void
It is definitely magnetized, by the earth magnetic field! This is enough with the variable reluctance for induce current in coil, and start the system.
Look before in this post the simulation of Ariovaldo, or the mine. Without a very little magnetic field, the system doesn't start.
And please can you indicate a place on earth without a little magnetic field?
Void
Quote from: isim on August 27, 2014, 12:36:21 PM
@Void
Hi Isim. I personally don't have a lot of faith in simulations as being hard evidence.
It would be nice if Mr. Robitaille could take the rotor out of his core after
running the device for a while, and measure the magnetization on the rotor
with a suitable gauss meter. It could be that the device does produce a significant
amount of electricity with only a low magnetization on the rotor, but it would
nice to confirm with some actual measurements of residual magnetization on the
rotor immediately after running the device for a while under load. I am not sure if
the rotor is difficult to remove from the assembly however.
ACG
Extra! Extra! read all about it!   http://hopegirl2012.wordpress.com/2014/08/27/qeg-project-updates-and-transformations
QuoteFirst, we need to express that WHAT WE ARE TRYING TO DO IS NOT EASY!
August 27, 2014
QuoteThe QEG is portable, the size of an average home generator, can easily hook up to your existing electrical system, and weighs approximately 120 pounds. The QEG can power your entire home, several of them can power anything from a skyscraper to a cruise ship, and you will never have to pay an electric bill ever again.
http://www.fixtheworldproject.net/what-is-the-qeg-.html  March 2014.
QuoteBetween the technical work that James is trying to do, and the intense travel schedule, and providing the most detailed and transparent updates to everyone, we've certainly met our share of challenges along the way.
Intense travel schedule?  That must be con code for 30 day vacation get-aways.  Self imposed and non contributing travels at that.  Instead of working locally, FTW goes to places lacking both components and building equipment.  Places yet to be both ever mentioned again and "Saved" as was the original claim mind you.  Uups, I just screwed the pouch on FTW's out of site is out of mind hypnotic money lure.
QuoteWe gave away this suppressed technology for free through opensourcing.
So you gave away a suppressed reluctance generator?  The inverse of which is powering the desk fans of houses all over the planet.  Open sourcing?  You mean a pdf file of an electric circuit had a link to download from?  Sort of like the billions of other electrical circuit schematics that can be downloaded for free.
QuoteNow engineers all over the world have a starting point for experimenting with this particular way of harnessing energy.
They already had a starting point for decades now.  But who am I to rain on your delusions of grandeur parade.  72 references to switched reluctance generators: http://www.scirp.org/journal/PaperInformation.aspx?PaperID=25035#.U6m_nijFKSo
QuoteWe are transparently reporting our progress DURING the research and co-development stages.
If I done so once I done it 100 times.  No longer going to comment on that one.
QuoteWe are not selling anything.
Instead you are directing all the heavy cost items to "select" sources for purchase (cough kick cough back).  You are structuring a multi level market percent give back to you.  You are receiving large donations for over a year, money of which could have installed multiple gas powered or solar power water pump systems in the places you used as bait.
QuoteYou may or may not have heard about this, but it noteworthy to highlight it here. This special on 60 minutes features the "Bloom Box". It's a new energy source that was developed that uses fuel cells. It does require a small amount of fuel to operate, but we have a suspicion that this was only done so that the company would be "allowed" to develop this product.
I know I heard about bloom box but those you hopegirl want to target are those who have not and those you know who will not bother to research bloom box.  This gets you more funding by using examples that have nothing to so with your qeg scam.  As predictable as a meth head without a fix and a pocket full of change your current blog uses yet again the history of non related ventures as support for your revenue.  Michael Jordan was once kicked from a team but look at him now?  She actually implied the qeg will work because Jordan and a few singers failed once but won out in the end.  I cannot believe people fall for hopegirl's Bee Ess.  But we have a suspicion?  I rest my case.
QuoteIn our stages of development there were additional expenses that went above and beyond what we originally put in our phase 3 budget.
Do tell.
QuoteEvery contribution no matter how big or small helps us to maintain the work that we do and allows us to report our results to the people....
To keep our transactions clean, we are closing donations on the QEG phase3 go fund me campaign. [paypal link]
Yet, using paypal.  What does she mean by "clean"?  The funding sites started to crack down?
QuoteIs it self running yet?
We have a well thought out strategy for the announcement of this. It will be opensourced to everyone so that it can be protected from suppression. To do this right, there is a lot of preparation work involved that will take some time, during which we are carefully providing open transparent information on the blogs that is safe to release in the interim.
That is long winded con code for NO.
QuoteWhere can I buy one?
For engineers that are interested in purchasing and building a QEG so that they can experiment and co-develop with us you can purchase a core from Torelco and the rest of the QEG kit from Tesla Energy Solutions LLC. T
Please walk through this kick back, I mean, this door.
Cough, clears throat...  And what of the UK report?
