Here is a way of looking at it:
You have an LC resonator.  Forget about the variable inductance, it's irrelevant.
Now to be more precise, it's an LCR resonator where R is the light bulb load.  Let's say the R is across the C.  The resonance frequency doesn't change when you add the R.
When you are not in resonance, the voltage across the C is low, and so the R doesn't really kick in.
When you are in resonance, the voltage across the C wants to get high, but then the R kicks in and starts draining power from the resonator.
Now you can look at the exponential decay of the resonating waveform for an LCR resonator.  It's just a Google search away.  As the resistance lowers the exponential decay in the resonating waveform is steeper and shorter in length.   With the light bulb load switched in, you can imagine the same kind of continuous "erosion" of the voltage waveform in the resonator.
So here is the pitch:  When you hit resonance, the LC resonator acts like a sort of notch filter/impedance matching filter that allows energy to flow into in the LC resonator, (that was provided a fraction of a second ago by the mechanical power from the electric motor) only then to be instantly drained away by the R, the light bulb load.
No resonance - no energy in the resonator - no significant amount of AC power going into the light bulb load.
Resonance - energy being pumped into the resonator because the resonator is amenable to energy being pumped in at the right frequency - and then that pumped in energy being instantaneously "stolen" by the light bulb load.
It's as simple as that - and there is no quantum nothing going on anywhere.
Standard disclaimer is that this would have to be checked out on the bench.  I may not be 100% correct, but what I state above is certainly not that far off from what is really happening.
Plus - we can't forget the major flaw - at certain angles of the rotor, the remaining magnetic energy stored in the core is shorted out - it goes into resistive heating of the coils - an energy sink into the oblivion of waste heat.  That's lost-forever power that never makes it to the light bulb load.
INTERESTING OBSERVATION:  When you are driving the QEG with the big honking electrical motor, there is still an AC sloshing of energy going on in the LCR resonator, even if you are not at resonance.  What are the waveforms and how much power is going into the light bulb load, even though the bulbs aren't lit?  How does that vary with frequency?  You would think that somebody would have checked this out but I am not aware of anybody doing it.
Even though it has been years and years for me, I could still dissect this thing inside-out if I really and truly wanted to.  Metaphysical proof that this is just an ordinary hunk of wire and metal.  I agree, the antenna nonsense is just pure desperation on Jamie's part.
MarkE
MileHigh, R does change the resonant frequency.  It is just that if the Q is high then damping is conversely small and the two frequencies are very close:
FDAMPED_RESONANT = FUNDAMPED * ( 1 - D2 ) 0.5
For example if Q = 10, D = 1/10 and FDAMPED_RESONANT = FUNDAMPED * ( 0.99 ) 0.5  ~= FUNDAMPED*0.995.
The damped resonant frequency can move by up to 30% lower than the undamped resonant frequency and the circuit will still ring.
isim
Quote from: MileHigh on September 14, 2014, 02:55:13 PM
Just for the heck of it, I posted to Kevin Blundell's YouTube channel.  He is the main guy responsible for QEG Canada:
Kevin,...
For information:
I just find it by hasard, do you know this site from Kevin Blundell (canada)?
http://truthseeker1313.com/about/
May been it's "your"  Kevin Blundell...
Isim:
I am pretty sure that it's the same Kevin Blundell.  Personally I have no interest in all of the Cabal/HAARP/Building 7/whatever business.  It looks like he would find kindred spirits on OU.
I am only interested in the people behind the QEG.
MleHigh
