0 Members and 87 Guests are viewing this topic.
synchro1
@MarkE,
Did you state this?
4. Magnetization is not adiabatic.
MarkE
Quote from: synchro1 on September 22, 2014, 08:12:56 AM
@MarkE,
You're the one that needs a dictionary!
Firstly: "Ferrite may refer to: Ferrite (iron)".
"Iron is a chemical element with the symbol Fe (from Latin: ferrum and atomic number 26. It is a metal in the first transition series".
Secondly: Transition series refers to the isotopes, magnets in line.
Thirdly: "The magnetocaloric effect (MCE, from magnet and calorie) is a magneto-thermodynamic phenomenon in which a temperature change of a suitable material is caused by exposing the material to a changing magnetic field".
Fourthly:
Synchro1 you really seem to take great delight in being horribly wrong.
No, iron is not ferrite.  Iron is a component in some ferrites.  Ferrites are ceramics of the general form: MxFe2O4, where Mx is a transition metal.  Iron can be one of those transition metals.  Confusion on that point may be why Wikipedia says what it does.  You can check with the people who make the stuff: such as TDK and Ferroxcube.
Or try Encyclopedia Brittanica:
Quoteferrite, ferrite [Credit: Omegatron]a ceramic-like material with magnetic properties that are useful in many types of electronic devices. Ferrites are hard, brittle, iron-containing, and generally gray or black and are polycrystalline—i.e., made up of a large number of small crystals. They are composed of iron oxide and one or more other metals in chemical combination.
A ferrite is formed by the reaction of ferric oxide (iron oxide or rust) with any of a number of other metals, including magnesium, aluminum, barium, manganese, copper, nickel, cobalt, or even iron itself.
A ferrite is usually described by the formula M(FexOy), where M represents any metal that forms divalent bonds, such as any of the elements mentioned earlier. Nickel ferrite, for instance, is NiFe2O4, and manganese ferrite is MnFe2O4; both are spinel minerals. The garnet mineral known as YIG, containing the rare-earth element yttrium, has the formula Y3Fe5
No transition series do not refer to:  "magnets in line".  The transition series are a number of atomic elements.
No ferrite does not transmutate.
Magnetocaloric effects are not adiabatic.
synchro1
@MarkE,
Quote from MarkE:
"Magnetocaloric effects are not adiabatic".
Clean your glasses off and see if you can read the last two words in this paragraph:
"The magnetocaloric effect (MCE, from magnet and calorie) is a magneto-thermodynamic phenomenon in which a temperature change of a suitable material is caused by exposing the material to a changing magnetic field. This is also known by low temperature physicists as adiabatic demagnetization".
Adiabatic means there's a temperature change without heat transfer. Look MarkE, I want you to stop confusing people while acting as a know it all.
You're really really STUPID!
MarkE
Quote from: synchro1 on September 22, 2014, 10:09:44 AM
@MarkE,
Quote from MarkE:
I see, so you're going for full-on offensive.  When heat is exchanged with the environment, the process is no longer adiabatic.
sparks
 @TK
  Know it's off topic so please excuse me.  Do you think you could improve on the distance of your wireless transfer of energy by using one wire between the qeg tank and the receiver tank?.  It looks like you are magnetically coupling the two whereas if you couple them capacitavely  (is that a word?) to ground distance would become less of a factor.  LC--------ll-----------------------------------------------------------------------------ll---LC
  This may not be that far off topic.  If I was going to rip someone off on a free energy device I would put some transmitter somewhere attached to ground and ground my receiver and run loads for the bedazzled using one wire transmission of energy using the Earth as the wire.
https://www.youtube.com/watch?v=zcvSXQHvFLg
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
