0 Members and 92 Guests are viewing this topic.
Farmhand
A resonant tank can be loaded and power drawn off and the phase alters this can be done while still maintaining resonant rise
on the resonant tank as long as the load power is less than the power pumping the tank. The advantage is that there is a higher
potential to affect the load than can be got from transformation ratio alone.
The phase between voltage and current in a running resonant tank can not remain at exactly 90 degrees because as the losses
exit the tank the phase must be affected to allow power into the tank.
None of that has anything to do with OU and never did.
When Tesla loaded his resonant transformers in power transmission modes the phase changed which allowed power out and
more power in. If it didn't it wouldn't work. A highly efficient tank might be able to resonate with a voltage and current phase
difference of near 90 degrees, but it is not possible for the phase to remain 90 degrees out of phase unless the tank
components were ideal, then the input would drop to absolutely nothing and the tank would resonate for ever.
So any tank setup which has an input of say 12.5 volts and 0.58 A DC has an input of about 7.25 watts of which a fair amount
would be getting input to the tank to cover losses. For that power to get into the tank the phase must be something other than
90 degrees. We can fiddle with things until we see 90 degrees but is that really true if there is an input to the tank, how could it
be ?
A phase difference between voltage and current of very close to 90 degrees while there is no load and there is 7.25 Watts input
means to me that either the very small phase difference is enough to account for the 7.25 Watts minus before tank losses or the
measurements are not quite right.
I do not see how a very accurate measurement can be got when the field from the tank affect the scope before it is even
connected.
Regardless resonant rise can be maintained with a load at other than 90 degrees phase shift between voltage and current.
I think that is an self evident truth. Is it not ?
PCB
I think in talking about the QEG and the people behind it we need a new lexicon. So I've started a dictionary of terms that might prove useful. I've really only just scratched the surface so contributions would be most welcome. Let's see how large a list of terms we can build. Here is what I have so far in no particular order:
SkullQEGgery: underhanded or unscrupulous behavior of FTW (HopeGirl's Fix the World project).
QEGgery: The act of taking money from from hapless individuals wanting to do good and shoving a QEG up their ass.
QEGing: A mindless individual that blindly follows much like a lemming.
QEGdulous: Showing too great a readiness to believe in the things put forth by FTW.
QEGiosity: 1. a strong desire to know everything about making the QEG and the people behind it; 2. the strange or unusual object that is the QEG
QEGibity: A term used to described a fraudulent scam that has the potential to solicit large sums of money from donations and crowd funding efforts. As in this idea has great QEGibility.
QEGity:  A state of mind wherein one feels one with the FTW.
QEGdary: A state a perplexity or uncertainty as to why the QEG does not work.
QEGster: A full member of the global QEG community who actively solicits and receives money.
QEGfundity: Those who profess deep insight and knowledge into the workings of the QEG.
QEGist: Somebody that is able to bring a QEG to full resonance.
Quote from: PCB on September 25, 2014, 12:12:23 PM
This is interesting, those 5000 engineers are quite clearly working hard after all:
http://be-do.com/index.php/nl/forum/china/585-assembly-mini-qeg-china
Awww... isn't that cute? But... experiments that I've done seem to indicate to me that a small unit like that may not be able to achieve the degree of parametric pumping that a larger unit will have. Let's not forget that the Big QEG's coils have inductances in the tens of Henries and that the turning of the rotor produces changes in the inductance otoo 20-25 percent, from the "rotor aligned" position to the "rotor unaligned" position.  It may not be possible for the small unit with the multiple rotor arms actually to start self-resonating by amplifying weak ambient fields and parametric pumping. It would be interesting to simulate this small unit, or at least calculate the expected inductances of the coils and the percentage of inductance change caused by the rotation of the rotor poles.
I'll be watching this one with interest, just to see if my feeling is right. If they can get it resonating at a reasonable rotation speed and without using magnets in the rotor, I'll be pleased to be proven wrong about my conclusion and might even build one myself.
You have to admire the quality of the build on this one:
http://be-do.com/index.php/nl/forum/southafrica2/500-update-qeg-team-cape-town
Yes, beautiful. These are the ones who built their own huge toroidal winder, too, I think! That, at least, might be useful in the future, if they go into the transformer winding business.
I marvel at the space these things take up. But even more, I marvel at the waste of creative talent, and this particular build is an example. Anyone who can build a working toroidal coil winder that can deal with 10-ga wire should not be wasting their time on this useless QEG project!
I've not been able find an open youtube channel for these guys, but I have found a closed part of the be-do.com for South Africa that I do not have permission to access. Interesting!!!! Here's the link:
http://be-do.com/index.php/en/forum/qeg-news/302-updates-from-cape-town-qeg-south-africa-team#1207
I wonder if there are behind closed door activities going on?
You just have to laugh at these "open source" projects that are heavily censored, locked up, and that don't discuss their progress, trials, successes and failures openly so that _everyone_ can learn from each other. Top Secret Open Source! Of course there is "behind closed doors" activity! There always is. Even in this very thread there are PMs flying back and forth that we know nothing about in public.
But I'd really really like to have daily reports from James Robitaille. He is the one who is supposed to know what he's doing, and you would think that the other builder teams would be looking to his work so they don't have to duplicate it on their own. How many installed 1.3 MHz "exciter" systems, only to find out later that 7 MHz was needed? (I also wonder if my pointing out the eleven AM radio stations nearby, broadcasting around 50 kW of AM power in all, between 1.27 and 1.32 MHz, had anything to do with that little "modification".)
So how does Jamie spend his days, I wonder? What exactly is he _doing_ on a daily basis in the barn? Does he just sit there watching the exciter sparking every once in a while, then when he thinks the core might be "conditioned" enough he runs up to "resonance", flips the switch and watches it die.. over and over... ? That has got to be a real drag. It is already 25th of September and I know it's starting to cool off in Pennsylvania. How is he heating his laboratory this winter?
http://www.youtube.com/watch?v=5Mnulep33-A
Well, maybe he sits indoors while the core is "conditioning" with the new 7MHz exciter coil and antenna, and he just goes out to check once a day. Still, it would be nice to see some reports, wouldn't it?
I guess that Hope, Val, and Jamie figure that they can get away with an update every four to eight weeks.  Hope will simply write up some marketing crap that says nothing.  So in four updates it will be Spring 2015!  In an Orwellian nightmare, chances are the people on the Be-Do forum will behave like perfect sheep.
Meanwhile, sleaze attracts sleaze and look what I found coming out of Hungary:
https://www.youtube.com/watch?v=VKzUFGtzeE4
http://www.qegquickandeasy.com/english.html
https://www.facebook.com/qegquickandeasy
You have to wipe the scum from your eyes and ears after looking at that.  A double-shot of sleaze!
These are probably fake pics but who knows.  If they are real you are looking at actual criminals that want to steal your money.
PCB
Quote from: MileHigh on September 25, 2014, 05:23:28 PM
I only looked at the first video and from what I saw this whole thing needs to be turned over to the SEC, FBI and there equivalents in the UK. It's gotten out of control! Jamie, Hopeless girl, and Val are the unwitting (witting) ring leaders. This is some serious criminal intent. I'm going to post this over at be-do.com.
