0 Members and 61 Guests are viewing this topic.
Separated at birth?
One thing for sure.... If Zappa was still alive he would kick HopeGirl's butt once he knew the whole story.
http://be-do.com/index.php/en/forum/welcome-mat/594-we-have-resonance#2744
Glendower: I can call spirits from the vasty deep.
Hotspur: Why, so can I, or so can any man; But will they come when you do call for them?
br549
Quote from: TinselKoala on October 05, 2014, 05:07:46 PM
Thanks, I'll have to read the whole thing, but at the moment, I see this:
Do you see? These ignoramuses say that my MicroQEG is an "obvious fraud"... yet I stand behind what is in that video 100 percent and can prove that everything in it is real and true. The MicroQEG and all of the associated items that I have demonstrated are 100 percent honest and ANYONE with a few dollars and a soldering iron can prove it for themselves. It is not like the "FTW QEG" where the published materials don't correspond to the actual device, the cost huge and the performance not as stated. My MicroQEG is _more real_ than any FTW QEG!
I told you that this would happen: They have a hard time explaining how my MicroQEG isn't OU, but the FTW QEG is... since the only evidence for any "OU" in either device is the VARs measurement, and I get 27 to one instead of a measly 4 or 10 to one like they do, even in VARs improperly calculated.
Once again, and I hope this gets back to the QEG believers: I challenge you, sidhabo,  thusly. My MicroQEG performs exactly as demonstrated in the videos, there is no "fraud" or fakery involved at all. If anyone doubts this they can build it for themselves for less than the cost of dinner and a movie. If they are so incompetent that they can't build and test it themselves, I will gladly send a unit to you or a qualified third party for testing ON THIS CONDITION. If it fails to perform as shown in the videos, I'll apologize publicly and never darken your door again. But if it DOES perform as shown... which it will, the people who have accused me of fraud will apologize publicly to me, loud and clear, and in addition will pay me my regular consulting fee for three days. Call it an even thousand dollars US. And in either case the tester or the accusing party can keep the unit.
But of course that crowd will never back up their claims with anything real. It is such a joke though, that they see my device and call it fake, but they can't tell that the FTW QEG has no hope of duplicating the WITTS fake QEG without cheating, themselves.
TK
I have just started following the QEG research with interest, and would like to say that am both impressed and interested in playing with your Micro-QEG. Is there a circuit available for it, and if so, could you point me in the right direction (where it is located). Normally I would search around and read all of your information presented on the forums and your YouTube channel until I found It, but right now (like a lot of other expermenters and researchers) my lab time is limited to the weekends.
Thank You; for the work that you are doing and for any information.
Quote from: br549 on October 15, 2014, 10:21:05 AM
TK
Thanks for your interest! The current schematic is attached below. The Zeners shown outside the mosfet symbols are not separate parts, they are the internal body diodes which are usually shown inside the mosfet symbol. That part of the drawing is a "legacy" and is left in as a tribute to the great Little Miss Mosfet.
Have fun!
Some notes:
-Don't operate without the output coil load, you'll blow a mosfet or both, instantly.
-Don't ramp up input power slowly, the oscillator might not start. Simply switch on to a 12 volt source that can deliver 5 amps but is fused at 10 amps. The operating draw will be much less but in the event that the oscillator doesn't start one mosfet will simply conduct all the current you can supply until it fails, hence the 10 amp fuse. Or current limiting PSU of course. Until you are familiar with the operation of the circuit it's a good idea to monitor the oscillation somehow.
-Don't create a groundloop with your instrumentation! You can safely scope across the drains with a scope or meter that is isolated from the input power supply but remember that the circuit common negative is not at the Drains! An interesting way to scope the circuit is to look at each Drain with a scope channel, both referenced to the circuit negative rail. If you do this then you don't have to worry about groundloops back through the power supply.
-You can use many different mosfets in this design, but very low Rdss work best of course and the current capacity must be capable of handling the real currents in the tank which can be 40 amps or more. (The voltages and currents in the tank are very real. It is only the _power_ that is imaginary.) The IRFZ44N or IRF3205 are good choices and if you want to boost the input power you can use IRFP260N for 24 VDC in, along with UF4007 for the diodes instead of 4148s, without modifying the circuit otherwise. The circuit will work with cheap IRF830 as well but at less output power and these mosfets should be fancooled. If you go over 24 VDC input you will need some kind of Gate protection for the mosfets.
-The circuit will also sometimes oscillate with only one operational mosfet. This is another reason for monitoring both mosfet Drains until the bugs are shaken out. If you don't have a scope, check the mosfet temperatures with your fingers and if one is much warmer than the other one, stop and find out why.
-Components are soldered to the copper surface of the board, laid out as below. Feel free to design your own board! Keep the drains-tank circuit-output coil heavy and symmetrical.
br549
Quote from: TinselKoala on October 15, 2014, 02:14:41 PM
Have fun!
Thanks TK ;
I'm ordering parts.
Have a great day.
