0 Members and 92 Guests are viewing this topic.
Quote from: SeaMonkey on October 18, 2014, 01:20:21 PM
The QEG as it presently exists is unimpressive in its
efficiency.  What it obviously needs is a single turn
winding at each end of the rotor, very low resistance
heavy gauge wire.  Then it would at least more closely
resemble an 'induction generator' and perhaps show
some increase in efficiency.
In fact, a side by side comparison with an improvised
induction generator made from an induction motor
might reveal some clues.
I pointed out the same thing quite some time ago, although I didn't specifically mention the shunt winding. And I also pointed out the reason that it doesn't work, and that is that the variation in inductance experienced in most small induction motors is too small to allow the parametric pumping to resonance to happen. That is, losses in the system are not overcome, because you might be going from 100 mH to 120 mH or so as the rotor spins past the pole pieces, whereas the QEG goes from something like 20 H to 30 H and back.
However it is easy to see that the induction motor will act as an AC generator when it's spun by an external source of mechanical power. Just not a very strong one, because of the rotor geometry, the shunts, and the small change in inductance.
QuoteSpeaking of timing analysis, in the interview Evens expresses some frustration in getting a full understanding of the timing analysis of the QEG.  What the hell one more time?  I actually discussed how to make a proper timing analysis of the QEG months ago on this thread.  Doing a full timing analysis of the QEG should be a no-brainer.
Don't you get it yet, MH? Just as with Rossi, and Steorn before him, any real scientific analysis of the device reveals too much! Therefore you will _never_ see a real scientific analysis of the QEG from any of the proponents like Kevin Blundell. Some builders with more integrity may eventually publish such analyses but of course "They built their QEG wrong, and they are paid shills of the PTB anyway".  How many teams are there who have achieved resonance in their QEG systems? A dozen, perhaps, and we know that all builders who persist and who don't electrocute themselves or blow core windings will achieve resonance. But how many actual reports of proper power in-power out measurements have you seen? Three?  One? NONE?  Do the math (tm RA) ....   ;D
Kevin has had a lot of very good advice, which he chooses to ignore without even considering it, apparently.
joel321
QuoteThe main word is  "thermonuclear fusion
Who cares what the main word is....I could call it poopiepoododdle...the fact of the mater is that it is an UNKNOWN force that is pooping starts all over the outer space toilet.
Those starts are just 1Watt light buld and 40watt light bulb and even there may be other start in the light spectrum that our animal eyes cannot see....or starts tooooooooooooooooooooooooooo far away that their light has not reached us yet! Simple Simple Simple to understand.
The main point is that it is a fact that light bulbs are floating around "dark matter" and they are gathering their energy for free from the "dark matter"... of course they are connected in the molecular level, that is 100% meaning that there is a hoover damb generator in the universe that is fueling them...plain and simple...DONE! 100% facts that FREEE energy exploded (came in to being) to fuel our milky way for billions of years and energy is being still fed....
If we look in the micro world, what! You are going to tell me that there is a micro hoover damn fueling the molecules to keep on moving? A proton circulating around a nucleus is just a mini QEG, a mini star that does not glow? Just a stupid molecule dancing around like a dumb ass wasting energy with no purpose?
I find it funny how you are referring to wikipedia  and not using your own brain to explain the unknown lol.
QuoteStars spend about 90% of their existence fusing hydrogen into helium in high-temperature and high-pressure reactions near the core.
Enjoy...
uhu uhu uhuh.....that explained where they are getting their energy...right? Besides that, explained how they are a GEOMETRICAL circle...and "floating" in the blanket of space? Who created life as a geometrical way of being...positive and negative? With out the other, things cancel out!!!! so the starts can be called positive and the dark matter can be called negative, the same principle is in a double A battery...is it not? The same principle is in magnetism....north pole south pole...yar yar yar...
I already mentioned that our current technology is very ancient since thousands of years ago. And through out these thousands of years, little steps have been happening....what makes you think that you are at the end of the stepping? Like if for some reason, 100 years from now, things would be as you think right now? Lol what a dork!
ACG
Quote from: joel321 on October 18, 2014, 12:52:40 AM
I only judge with my eyes man. I don't understand energy that I cannot see...lol
I'll play along "MATE" is not a light bulb a resistor?
The filament is rated in watts, which is a "fancy" word for it's thickness relating to the vacuum gases inside the incandescent bulb too. BUT!! it still means that the greater the energy, the brighter the bulb.
SO!!! you are telling me that the brightness is only picked up by the video camera VS my eye balls? IOW< my eyeballs would not see a greater shine from the bulbs (resistors) as much as was recorded in a camera? Call me stupid, but video cameras will detect light differences as much as eyeballs...lol
Aside from that, explain to me how a "star" is shining in the sky all alone with no 120/240v AC cord connected to it?
Then you need to get your eyes checked.  By the way Naima, Hope, whatever,  Y u no get much $ dis time round?
You are correct, in 10 years qegs will be all over the place.  I suggest you buy a sturdy umbrella before hand.  Ever heard of the term "hitting the fan"?
@PCB
What I tell you.  Some define resonance by the simple illumination of a bulb.  Very sad really.  Some even take the leap of defining over unity just the same.
joel321
QuoteEveryone knows that stars do get their power from 240v extension cords. (At 62.365 Hz) They are obviously very long, and there is high resistance in them because of this but, the stars are powered from coal fired electric plants here on earth.  This was documented and proven way back in 1926.  This is where string theory comes from....the long electric cords are like "strings".  This is proven physics and can not be disputed by any intelligent, educated people.  If you look very close at NASA photos of stars, you can almost see these cords.  The government tried to keep this a secret but, it got out in 1968.  A lot of people do not think we should be powering the stars, and that the money could be better spent here on earth but, we are still doing it.
Hey bill you are one funny skunk that will get ran over by a gasoline engine car eventually. Lol
Lets keep it simple...lets think of everything being an OCEAN. Water (of course) air, light, sound, taste....are all oceans. The universe is an ocean where things swim aroun in a place with no gravity...heck, there may be may gravity attention whores out there...lol Get it? And not only that, they are only making the starts shine because they have consciousness that they need to make a start shine....is not because she has tits, it's just because it is encoded. Just like humans are encoded to reproduce. Blah blah blah...
Back to the "ocean" analogy, it's just energy traveling through air, water, vacuum, walls, gold, silver, diamonds, dark matter, energy is raveling through out all over for FREEE.
The only reason there are thousands of fishing boats is because they make little money.....the only reason that there are not thousandths of Hoover damns is because they won;t allow it....lol...pretty simple shyt!
At any rate, I find it weird that you talk about Hertz with out figuring out where they came from....like you don't questions where the vibration laws came from? I understand, it is easy to just focus on the human "laws" (the present) but the fact of the matter is that the frequencies are already there since the turtle was carying the earth on it's back!!!
