0 Members and 50 Guests are viewing this topic.
@Pirate: There is a difference between "near field coupling" and the usual far-field reception of a radio station's broadcast power. If you are in the "near field" of the antenna source your extraction of power will indeed load the source. But the issue with the Robitaille's scheme isn't so much "stealing power" from the radio stations, although it is easy to arrange some little sparks. The real issue is that the system as described, with the exciter circuit connected to the motor-driven QEG,  is actually a _transmitter_ not a receiver and will be interfering with the legal broadcasts of the radio stations. Also any detected power around 1.3 MHz is going to be coming from the radio stations, not the "quantum energy zero-point field".
Pirate88179
Quote from: TinselKoala on October 28, 2014, 11:39:51 PM
TK:
I thank you for that explanation.  It makes perfect sense.  So, if I have 50 radios at my home tuned to a certain station,  I am not "hogging" the signal and preventing others from receiving it unless the station boosts its output power?  That is what I "thought" I had learned a while back.
MarkE
Quote from: Pirate88179 on October 29, 2014, 08:40:55 PM
TK:
Sort of:  In the far field from a non-directional antenna the incident power spreads out evenly perpendicular to the direction of propagation.  The power density falls as a square of the distance from the transmitter.  You can visualize this as a bubble that just keeps expanding forever.  The total power is spread across the surface of the bubble.  One does not have to get very far from the source before the power density has gotten very low compared to close to the source.  That makes it hard to come up with an antenna large enough to intercept a significant percentage of the radiant power.  However, the power that any antenna does intercept (assume matched impedance) gets directed to the receiver and does not propagate further.  Otherwise we would be able to multiply the power of a transmitter by setting up one set of receiving antennae after another in the propagation direction.
joel321
Quote@Joel I have been doing some research and a lot of tinkering and have invented a solar powered QEG that I call the LEG. I'm in the process of building a massive array of these little LEGs to power my home and to send power back to the grid. I will to share this with you and everyone else here provided that you send me some money when you get it going on the honor system, and help with crowd funding efforts to bring my LEG technology to the poor peoples and the world. Here goes... To build this you will need some 12 or 14 gauge copper wire and a galvanized nail. I got the copper wire from the electrical wiring in my house, and pulled the nail(s) from my deck. Take a "L"emon and insert 3 copper wires each about 3" long twisted to together at the top in the right hand side of the lemon. Insert the nail with some copper wire attached in the left hand side of the lemon. Here is this break-though I made. Take about 2ft of copper wire and make a pig tail coil about 1" inch in diameter. This is equivalent to the exciter coil in QEG and captures the quantum energy in the environment. Insert one end of the coil into the center of the lemon between the two electrodes. It is important that the coil is perfectly vertical. For this device to work the coil must be vertically polarized and it acts as a quarter wave antenna. Here is the other important bit. Place the whole assembly inside a cardboard box and bring the electrodes wire out through the sides of the box. Close the lid of the box so that you can physically see it. Now comes the hard bit. Connect a voltmeter across the two electrodes wires and note the voltage. You now need to condition the coil with positive spiritual energy.  If you do this right the voltage will start increasing. Like I said I have put together about 1000 of these LEGs connected in series and parallel in a room of my house and have closed the door so that they can't be seen. Through humming and meditation I've been able to get more than 10 KW of power for several weeks now. Also I have found that by capturing quantum energy the lemon self rejuvenates and it never rots. Good luck with your build!
I like your sense of sarcasm, but lest get real....those little pesky atoms are getting FREEE energy since millions of years? Humanity has been blinded by human made electricity that you have to pay....while even getting a female pregnant is giving life for free (well you still have to pay for dinner ) but it is FREE energy none-the-less. IOW, you don't understand FREEE energy only "renewable energy" which such definitions come from people whom put an electric meter on your house! You need to step in to the matrix lol (referring to the movie).
Mother nature has all of this FREEE energy evidence, why is it so hard for you to believe in FREEE energy? Hhmmm, let me guess, a-they tell you there is none or b-you don't know about it....
Think about energy?
What is it?
Man made?
What is the SUN paying for it's energy?
And how is the sun getting it's energy from the dark spaces?
Who is giving the sun energy?
What decided to even create the sun?
It is 100% facts that humans did not create the SUN nor the STARS, just little things like taking peoples money and take a las vegas vacation with young females...lol...which does not sound bad, but that's only based on greed and not truth. As a matter of fact, i'm sure if you were ritch, you would not even be here...lol....it is simple....
Seeking truth because you want to see the truth or because the lack of money? (disregarding personal feelings)
Can you explain what evolution means? We all have to be fortune tellers, not just focus on the present.
Trust me, when you understand things further, your life becomes easier....the only hard part is trying to convince the money greedy people to give it to everyone...and then they need to go to therapy about loosing their millions. Pretty simple stuff.
The way you are responding is just a way of resentment when bullies made fun of you when you where young, which makes you a bully now in the your older years...also, has to do with frustration regarding not understanding how to be rich too! If you understand how forensics work, you will understand a lot of things.
Right now this PARTICULAR QEG is being therapy for all of these non-believers......you have the FACTS of the ATOM, SUN, MOON, EARTH, GALAXY, LIGHT, SOUND, ELECTRICITY, and you don't believe in FREEE energy, you must be blinded and not really smart man!
MarkE
Yet another wall of non-sequitur text from Joe fails to counter the fact that the QEG has never performed as claimed by its promoters.  The QEG's demonstrated performance is as a dismally inefficient power converter.
