Magluvin
Lets say we negate the possibility of any field in the cores and are null of magnetic field. Unless possibly Earths field has a part in it.(Rotate the box in different directions to find out?) If the thought of just the changing value of inductance is the effect producer, then there is another way of changing the inductance other than changing the core values as Luc has demonstrated.
Say we have a mot, uncut, and then apply switching on and off across the primary coil. lol, sounds nuts and probably not even worth trying by anyone that read this, but by shorting and opening the primary winding, you are very effectively changing the actual inductance of the secondary.  So in a way, testing this out may possibly show if just the change in inductance is the real root of it all?  lol Still sounds nuts to me, but I had to put it out there. :o
So I suppose the proposed test would involve switching between short and open of the primary at a particular freq, sweeping to find resonance. ??? I would recommend cutting the cap off the transformer and remount it with an insulated spacer, to keep the core open(gapped), just as Lucs core always is more or less as it spins, except for when it goes BVVVVP!   That sound reminds me of the loud 60hz hum of an outside hv power line that goes to ground or to another phase line. BVVVP! ;D Just about exactly like that is how Lucs box sounds.
I was reading a bit on magnetic amplifiers before this post and the thought came to me.
Like who would even think of such a thing? ;)   Magnutty  :o , thats who. ;D
Now that would be clear and 'easy' free energy if it worked.  ;)
Magnutts :o
gotoluc
Quote from: wattsup on April 15, 2014, 01:06:55 PM
@gotoluc
About your 1 watt OU testing,
the best spinning sphere magnet I have ever seen was on youtube, a guy showing a sphere magnet rotating inside a Rodin coil. That magnet was turning so damn fast. So this proves to us that a Rodin coil produces a great rotating impulse matrix inside the donut hole.
alternator stator wants is to see is a nice rotating field inside of its hole. hint hint
wattsup
Hi wattsup,
thanks for the details.
Today I was able to confirm there is not a 1 watt gain in my solid state version of the QEG. Ended up I had to use a wheel utility power meter to confirm. Good thing I was using 60Hz and 240vac.
About the Rodin coil idea. Don't you think the ball magnet RPM will be too high of a frequency for the steel lamination of a car Alternator?... also, why would you think the ball magnet rotation won't be affected by Lenz once the Alt. coil are under load?
Thank for sharing
Luc
Magluvin
Quote from: gotoluc on April 16, 2014, 12:31:41 AM
Hi wattsup,
Thank for sharing
Luc
Hmm. Its an interesting thought of using an alternator to have a bunch of coils on the stator with capacitors, and dont even apply power to the field coil in the rotor. The armature fingers will to the closing the gap deal on the stators and changing the inductance.
Rewind the stator with lots of fine wire to simulate or come close to the inductance of the mot sec.
Then just drive/spin the alt to resonance with caps on each of the 3 stator coils, all of different phase.  So this way probably no BVVVP! sounds. ;D   Alternators are pretty sturdy.
Mags
gotoluc
Quote from: Magluvin on April 15, 2014, 11:57:55 PM
Magnutts :o
Hey Mags,
I forgot to mention something that may help this magnet flux question.
I was doing more tests on trying to find a different resonating cap value on the high voltage coil and found one that was giving a small rise in voltage, then for some reason I shorted both the low voltage coils and instantly the voltage rise fell to nothing and would not climb back.
Would this not confirm that a magnetic flux was present in the cores until I neutralized it by shorting?
Luc
Magluvin
Magnutts :o
Thinking about it a bit more, there may need to be 1 change to shift the inductance more like Lucs test box does.
The way I described above, the sec has a particular inductance on its own with the cap off  and away from the cut ecore containing the mots sec winding. Then when the cap is rotated to where it completely covers the cut ecore, the inductance of the sec coil increases.
In my shorting the primary config, the sec would have its own self inductance, but when the primary is shorted, the sec inductance goes down, opposite of Lucs box demo.
Not sure if it even matters if the inductance is shifted one way or the other to get the effect. But to get the sec inductance to increase by shorting the primary, all we have to do is instead of shorting the primary, just connect another inductor to the primary, and the sec inductance will increase, simulating the increase of sec inductance instead of lowering it.
Like I said, not sure if it matters one way or the other. Either way, the sec inductance will change by affecting the primary as described. ;)
As I said, if the change in inductance is the prime function of sec output of this device, then this changing of inductance will either work, or possibly it is not just(or not at all) the change of sec inductance that causes the effect. ;)
Mags
