0 Members and 94 Guests are viewing this topic.
Magluvin
Quote from: gotoluc on April 16, 2014, 12:51:36 AM
Hey Mags,
I forgot to mention something that may help this magnet flux question.
I was doing more tests on trying to find a different resonating cap value on the high voltage coil and found one that was giving a small rise in voltage, then for some reason I shorted both the low voltage coils and instantly the voltage rise fell to nothing and would not climb back.
Would this not confirm that a magnetic flux was present in the cores until I neutralized it by shorting?
Luc
If you are saying you still have the primary on the open ecore with the sec, then I would put an amp meter across the primary(with series resistor as current limiter) to see if current is in the primary.  but thinking about it more, loading/shorting the primary will lower the sec inductance sending your resonant freq much higher. Sooo, larger caps to get back into resonance?  Then just leave the sec and cap alone, and just load the primary, lowering the voltage and increasing the current of the output. As the primary load changes, say when the light bulb goes from cold to hot, the freq will need to be adjusted for the 'hot' load to be in resonance, because changing the load on the primary will affect the sec inductance. The more the primary conducts, the lower the sec inductance will be. ;) So the appropriate cap and freq of spin will be needed to match peak output of the primary.  Seems complicated, but its not, and probably very well worth trying. ;D
Mags
Mags
Magluvin
Hey Mags,
Luc
Lol, I said all that and neglected the flux question... ::)
Well it seems we have to operate at resonance of the LC in order to get any output at all.  In your setup, if you remove the capacitor then adjust your scope to a more sensitive level, then if you see 'any' output, even tiny, I would say there may be some week field in the core, and when you do set up the LC for resonance, it is a very pronounced resonance. very.  ;)   Nice big fat resonance affect compared to ordinary 'generator'' action using even a very weak field in the core, shown by looking at the sec without the cap, having no resonance advantages.
Did you try the compass tests I mentioned earlier?  I think it was yesterday.
Mags
Jimboot
Quote from: MileHigh on April 15, 2014, 09:46:45 PM
Well at least this thread is not going off in as many random directions as the Akula 30 watt generator thread.
Nonetheless, for Wattsup:  The Rodin coil is just electronics quackery.  There is no vortex, it doesn't do anything special at all.
Maybe but they are fun to play with :)
Magluvin
One more thing I just thought of.  have you tried backing off the gap distance at all from what you have shown?  Like open the gap say 1 or 2mm then try again to see if there is output, without BVVVVP! happening at all. Your function gen only goes to 1 decimal point. Once you have the freq that is closest to resonance, you could try doing small adjustments to the capacitance to fine tune even further.  This is what Romero was doing, increasing the spacing of the rotor mags and the pickup coils to 'reduce' lenz drag, but when the speed was up to the resonance of the coils, they would sing well at a distance. He said he spent a lot of time on those coils and tuning.  To get all 16 pickups to sing at the same freq, let alone have the same voltage output for best and equal output of each coil would be a daunting task.  Say if one coil was a bit off from the others, its output may not even add to the output cap due to it doesnt even hit as high a voltage as the others. Daunting task indeedy. ;)   Most people may not even consider those things.  Hand wound, fine litz wire, backing washers and backing magnet adjustments. But he took on that task and look what he made. ;D
Mags
Magluvin
Quote from: Magluvin on April 16, 2014, 01:26:09 AM
Mags
Lets see, what would be a good way of getting rid of any magnetism in the core, or at least reduce it to a possible minimum?  Remove the coils and bake in the oven at 500deg for 45 min?  ;D
Remember also, the 'welding' on the core could easily implant a field in the core. ;) ;) Just thinking of possible ways it could have gotten there and if we could get rid of it all, if there is a field, would the box still do the BVVVP! or have any output at all? ;)
Im not trying to debunk. But to me, it would be natural to think along these lines first to eliminate things to find the target cause of effect.  Like I have been posting about since yesterday. ;)
Mags
