Lawrence, you are acting as a great DISinformation agent. Why don't you tell the TRUTH about the Taiwan QEG? Tell us how the coils shorted due to improper HV design. Tell us what the _actual_ measurements of input and output power were, and why nobody in Taiwan, or anywhere else, is getting the performance promised by the Robitaille clan of liars and dupes.
There are obviously some things missing from your first photo. Can you tell me what they are?
And feel free to demonstrate that the second diagram works as claimed. You cannot, and neither can anyone else, because it simply DOES NOT, and this has been proven over and over and over, by everyone who has tried to build it.  Where does the AC input from the mains suddenly turn into DC power for the specified DC, brushed, motor, for example?
You said earlier that you could just buy a working QEG from Timothy Thrapp, that money was no problem. And I am calling your bluff. You cannot, and will not, ever do that simple thing. Meanwhile you continue to make false claims of OU performance for various devices that somehow always need to be plugged into the mains or use huge batteries, except for tiny short periods of time when you can draw off more _peak power_ ... but not more energy... than was used to run them up to speed.
Let's face it: If any of the devices you have promoted are actually "OU" in any way, it would be trivial to demonstrate it unequivocally, and the inventors would not be paying for their electricity. But none of them are, and so they cannot be, and so the inventors are _still_ connected to their national grids.
You never did answer me: From where do you get your electricity? Why did you not answer? Is the answer too embarrassing, perhaps? The person who claims all these various OU devices is still plugged into the grid? How can that be? I know the answer, and so do you.
From the official FAQs on the be-do forum:
QuoteWhat is the output of the QEG, so that the input for the inverter is clear ?   -Range of Voltage: 180-600 volt DC
-Maximum Power: We tested up to 10kW and it's a conservative rating
http://be-do.com/index.php/en/faq?faqid=15
This is another of many bald-faced LIES that the FTW people have emitted concerning the QEG.
No QEG anywhere has ever come close to an OUTPUT of 10 kW. The most we have ever seen demonstrated or even reported honestly is a few hundred watts, demonstrated not by measurement but only by lighting up a few light bulbs.
VARs are not Watts of usable power.
QuoteThe so called free energy, over unity is intiated in the device by the plasma created by the spark gap in this device. YES or NO? If not what is spark gaps function here?    NO - the exciter circuit is a tank circuit tuned to 1.3 MHz which is one of Earth's high resonance frequencies (not Schumann). Each 2-3 second spark superimposes 1.3 MHz pulses on top of the 400 Hz sine wave. This conducts local atmospheric energy into the generator core. This has effect of conditioning the core to maximize magnetic flux and output.
The exciter coil/spark gap is only used temporarily to condition the core. After a couple of weeks of use it's removed (not needed anymore).
http://be-do.com/index.php/en/faq?faqid=26
What were those frequencies, again? 1.3 MHz is right in the middle of the AM standard broadcast band and in Pennsylvania alone there are ELEVEN AM radio stations broadcasting a total of nearly 50 kW of radiated power between 1.280 and 1.320 MHz. Furthermore, James Robitaille himself has changed to 7 MHz, now that he realizes he cannot legally operate a _spark gap transmitter_ at 1.3 MHz without interfering with licenced broadcast stations. Furthermore, no QEG for which we have seen data or screenshots is resonating at 400 Hz. Every one is resonating at a much lower frequency, below 200 Hz. And even furthermore.... "a couple of weeks" has turned into over a YEAR, and there is still no hint, anywhere except in Lawrence's imagination, that any QEG build has experienced any "conditioning" of the core, nor have they come anywhere close to "self running".
And of course the biggest howling LIE of all is still there too:
QuoteHow is the QEG started up if it doesn't require fuel?    All that's needed is to spin the machine up to resonance. At that point it will run itself. It can be
started using existing electrical power if available, or a crank mechanism, or a battery powered
motor-start system. A battery start system could also keep its own batteries fully charged, by
tapping some power from the generator.
http://be-do.com/index.php/en/faq?faqid=5
As we all are aware (except Lawrence of  course) many QEG builders have been able to "spin the machine up to resonance" but not a single one of them has ever come close to "At this point it will run itself". This claim is simply a total lie, emitted by HopeGirl in order to get people to donate money. In fact no QEG has even ever "run" AT ALL, since they have always been DRIVEN by a honking big electric motor connected to the mains supply (or perhaps a bank of batteries and an inverter). DRIVEN is not RUNNING. And the image of HopeGirl starting one up using a crank mechanism cracks me up every time I think of it. Lord knows the girl needs some exercise, but this is just a ridiculous claim all the way around.
So why.... tell me why... is the Be-Do forum still carrying these PROVEN LIES and pretending they are true? Never mind, I know why, and so do you.
PCB
Quote from: joel321 on November 15, 2014, 01:25:15 AM
Let me share a scam from evil people that really want to hurt you and just take your money!!!
I already mentioned that I sell stuff on craigslist, this is just one of the scams I face!
Scams are easy to spot!
In fact I see the negative people here not believing in QEGs as scamers. River + alternator = FREEEE energy!!!!!!
I find your meaningless chattering on off topic matters and your denial of the number zero to be completely turdic. I'd truly like to flush you away from this forum.
Cap-Z-ro
It wood appear joel just doesn't seem to understand that people don't like to be interrupted when they are beating a dead horse or just beating off.
C'mon joel get with the programming.
Regards...
MarkE
Quote from: Cap-Z-ro on November 15, 2014, 08:16:48 PM
Regards...
Does that mean that you conclude that the QEG is a dead horse?
