0 Members and 95 Guests are viewing this topic.
Magluvin
Lol, if youu added mags to the open ecore poles N S N, glue, what ever it would take, then run the thing, would there be as much or more output than what you are getting? It would be a scene from Jaws, " I think we need a bigger box."  Stronger at least.  ;D   But then more lenz, more BVVVVAAPP!!!
But resonance should be higher freq. Stronger field(stiffer, tighter string on the guitar)
Just thinkin
Mags
Johan_1955
Quote from: ramset on April 10, 2014, 03:05:00 PM
Johan
Thanks for posting your "old" experiment.
It would seem you have achieved results that show OU?
Chet
Hi Chet,
Right, its a standard single phase motor, has 2 coils each over 2 core's, only the rotor also has a coil! ;-))
Regards, Johan
Jack Noskills
You guys are familiar with Rotoverter concept ? Idea is to rewire the stator windings to get stronger electro magnet and reduce current flow through the drive coil. To further reduce power usage parallel capacitor is used to get system into resonance. Problem with this is that there is the rotor that also have coils shorted, so when rotor starts spinning it will create back emf to stator coils putting it out resonance. Proposed solution was to use capacitors adjusted to load: when load changes caps need to be also changed. This could be difficult task, don't know.
So what I am thinking is that what happens if coils in the rotor are just not used at all (disconnected or removed) ? Would the rotor still rotate ? Why not, if it is made of iron. Stator's rotating electro magnet would still attract the iron rotor. There would be less torque but if stator coils are in resonance then they would form stronger electromagnet. Another option is to use higher voltage and more turns in stator coils.
Would the result then be a motor without any drag and low power consumption because of resonance (it would run on reactive power only) ?
Farmhand
Here's a good page with animations for induction motors, if you scroll down nearer the bottom there is rotating fields and squirrel cages.
http://www.animations.physics.unsw.edu.au/jw/electricmotors.html
jbignes5
I know this is off topic a bit but please watch this video of a real explanation that describes the Universe we live in. This is so close to the truth we must understand this completely.
https://www.youtube.com/watch?v=EguwaPRmamY
