0 Members and 89 Guests are viewing this topic.
jbignes5
Quote from: jdsanders on April 16, 2014, 08:15:39 PM
Cool lecture, jbig.  Thanks for the link.   :)
Yeah this group is actually real scientists who are seeing things in a new light very very informative for re-educating people to the way it really is.
F_Brown
Quote from: jbignes5 on April 16, 2014, 06:30:35 PM
If you use magnets in any other section of that patent then you loose the loop effect. This would destroy the concept. Tesla had this patent as the AC system he HAD designed. It was an improvement to that system as the text of the patent reads. The rotational fields can be simply adjusted by the wind direction which can be set to rotate in opposite direction the prime mover rotates PLUS the loop can be self maintained in that way. Also the belt was a pony break and he notes that this system was quite impossible to stop but there were limits to this. Those limits are the physical wire itself. Go beyond the current capability or the insulation and poof it would break.
This dynamo seems to me to be a straight forward alternator with electrically rotated stator poles that can be used to increase or decrease the effective rotation speed of the armature.  What do you mean by loop effect?
If one rotates a movable stator with magnets physically, or poles generated by coils in a fixed stator electrically the effect would be the same, provided the the strength of the magnets and the strength of the coils were the same.
Where does Tesla claim the device is practically impossible to stop, in the patent or somewhere else?
When the patent is adopted to a single shaft it creates a self pumping loop which you can harvest the extra current for use in the prime mover and additional loads via a transformer. The belt again was used to check the motor and increase the current in the rotor coils. What if you connected the belt to a transmission? Hmmm... This is where I connected this to the Pierce arrow experiment.
What so you mean by adopting the device to a single shaft?  What exactly would be attached to that shaft?
Also as I understand the Tesla's Pierce Arrow, there was an antenna and have a dozen tubes of some sort.  Are you trying to imply this dynamo was responsible for part or all the the reported self-sustaining operation of the vehicle?
chrisC
WITTS broadcast tonight:
"Fix The World organization has been making progress with their QEG (quantum energy generator) project.  Although the machine is capable of producing significant electrical power without a conventional fuel source, there are safety considerations that builders may not be aware of. Energy being derived with these types of devices is not only electrons like most engineers are familiar, but include other particles and fields not commonly taught in conventional electrical theory.  In addition to high voltages being generated, dominant energy systems can manifest large quantum energy pulses showing up at a distance which could cause fires or harm electronic equipment. WITTS Ministries advises experimenters to exercise extreme caution and urges serious engineers to consider taking a few classes before working at significant power levels.  Sir T will have more information on this week's broadcast."
http://www.witts.ws/
jbignes5
Quote from: F_Brown on April 16, 2014, 08:18:52 PM
If one rotates a movable stator with magnets physically, or the pole of fixed stator electrically the effect would be the same, provided the the strength of the magnets and the strength of the coils were the same.
Also as I understand the Tesla's Pierce Arrow, there was an antenna and have a dozen tubes of some sort.  Are you trying to imply this dynamo was responsible for part or all the the self-sustaining operation of the vehicle?
The loop goes like this. It starts in the magneto. then gets put through the field coils. Since the field coils are of high voltage and low current there isn't much magnetic field created. The high voltage field then gets induced into the rotor coils which transform the high voltage field into low voltage high current. This creates a very large magnetic field in the rotor and a heavy current. The magnetic field locks onto the field cores and rotates cutting the field coils and generating more high voltage which then induces into the rotor coils again. This is a loop between the rotor and field cores. The heavy current can be tapped as shown and put through the transformer shown on the patent. Also Tesla states that the motor or prime mover should be made how he specifies in the patent. Yes it can be all done on the same shaft in fact that is probably the best way to do it, for timing issues.
The antenna is a ruse and there is no indication it was used at all. The box was the impulse controls and Tesla designed special spark gap and diode tubes for the box. The motor control was via Tesla's standard magnetic motor control. He has a patent for it as well and hooked to the gas pedal.
The book Secrets of Cold war Technology, i believe has the story about the motors he was developing and had Westinghouse produce them for him. And yes this was all together one unit.
http://borderlandresearch.com/book/secrets-cold-war-tech/chapter-1
markdansie
Quote from: chrisC on April 16, 2014, 08:29:29 PM
Bullshit meter pegged here, they want to cash in as well lol
This is hilarious
Will it ever end?
Just Like John R , Brady and many others they will milk the gullible as long as possible.
Any chance WITTS will show a verifiable working model its only been 20 years lol?
Mark
