Quote from: Groundloop on December 08, 2014, 04:03:26 PM
Mark,
Thanks, so if we do the opposite, take away core material, then the stored energy will go up?
GL.
Changing the amount of core material by "magic" will not change the amount of stored magnetic energy.  Energy does not materialize out of "nowhere."
Groundloop
Quote from: MileHigh on December 08, 2014, 04:18:58 PM
Mile,
I agree 100%, energy can not be created out of nowhere. But here is some thoughts, if the amperage
flowing in the coil (tank circuit at resonance) has reached its maximum and all the energy is stored in
the magnetic field, and at that exact time we switch in more core material, then the inductance will go
up, and the current has not have any time to go down, then the total energy stored in the magnetic field
must go up, because that is what the math formulas is telling us. Energy stored in a magnetic field = 1/2*L*I*I.
So if the ampere is constant before the added core and after the added core, then the inductance L will be higher
and the stored magnetic energy will be higher. Am I wrong about this?
GL.
dvy1214
Quote from: Groundloop on December 08, 2014, 05:13:52 PM
Mile,
GL.
My understanding is that inductance is actualized by current. I do not believe that sort of transient phenomenon would be received by the current in the fashion of rise in W.
Groundloop
Quote from: dvy1214 on December 08, 2014, 05:32:58 PM
Dvy,
It is a fact that the the resonant frequency goes down when we add core material. The only way
the resonant frequency can go down is by the result of a change in the inductance to a higher
value. So if the inductance is changing to a higher value and everything else is constant, e.g. current,
then must not the stored magnetic energy also change to a higher value? Or will the current change
to a lower amperage when we increase the inductance by adding core material?
GL.
MarkE
Quote from: Groundloop on December 08, 2014, 04:01:42 PM
All,
Now the next question.
Do we need to use any energy to switch a AC signal from L1 and to L3 by shorting the L2 coil?
(I know there will be some losses and the output will be lower than the input signal.)
GL.
This garden path leads nowhere.
