MarkE
Quote from: Groundloop on December 08, 2014, 06:56:14 PM
Mark,
>>Closing the connection on the middle coil requires energy transfer to magnetize the right hand transformer.
Agree 100% on your last sentence, but that was not the question. The question was, do you need to use any energy
(or actually very little energy) to short the middle coil to be able to transport energy from the input
to the output.  Don't bother to answer. You can actually transfer AC or pulsed DC from the input
to the output by shorting the middle coil. So this setup is a on/off switch for that energy transfer based
on the status of the middle coil (shorted or not). And you do not need to spend any energy to switch the middle coil.
In real life you need to use an transistor or relay to switch the middle coil, so by using very little energy, you can switch
on and off a large energy from the input to the output. So I'm not building anything based on an impossible premise.
I'm basing my thought process on real life research that I have done on magnetic amplifier setup using
toroid cores and coils during the past two years.
GL.
Whatever scheme you are cooking up the energy required to operate the switches that change the system state is in the noise.  It is the system states that matter, and each one of these operations is lossy.  Devise any switching mechanism you like and you will find that the First and Second Laws of Energy will not be defeated.
Groundloop:
Quoteif the amperage
flowing in the coil (tank circuit at resonance) has reached its maximum and all the energy is stored in
the magnetic field, and at that exact time we switch in more core material, then the inductance will go
up, and the current has not have any time to go down, then the total energy stored in the magnetic field
must go up, because that is what the math formulas is telling us. Energy stored in a magnetic field = 1/2*L*I*I.
So if the ampere is constant before the added core and after the added core, then the inductance L will be higher
and the stored magnetic energy will be higher. Am I wrong about this?
I suggest that you take a look at my very simple example and try to answer it.  Once we we get the answer for my example then take a second look at your example above.
Hey Joel! Here's your chance!
Free Energy, guaranteed by HopeGirl, only 5500 dollars US!
QuoteDue to financial issues we have to offer our QEG project parts for sale.
All parts are new and have not been assembled.
We have a Torelco Gen II core, rotor, Shaft, endplates, shrouds, bearings, unopened new certified Loctite 640 and hardener, 2 hp Leeson motor, Variac with Bridge,6- 240v 100w light bulb load board, Pulleys for rotor and motor, Exciter coil built with spark gap and mica variable capacitor, RF meter, 900 ft of 14 AWG wire.  We are in the San Diego area. $5,500 If you are interested please send an email
to (email redacted)
http://be-do.com/index.php/en/forum/wanted-offered/620-qeg-parts-for-sale#2899
MarkE
Quote from: TinselKoala on December 08, 2014, 10:04:29 PM
So the Robbing Robitailles are willing to forgo their very own hold on perpetual energy for just $5500.  Demand for their consulting services must not be very strong.
Quote from: MarkE on December 08, 2014, 11:08:28 PM
Sorry, I didn't mean to imply that the Robitailles were selling out. This offer appears to be from a builder in San Diego who has "lost the faith" and found better uses for the money and time.
