orbut 3000
True, true. When someone says you can't put one cent into an empty box and get two out in return, ask him: How far can you throw a dishwasher?
Checkmate, bro.
Pirate88179
Quote from: joel321 on December 21, 2014, 01:21:07 AM
Pirate88179 arr arr!
The whole purpose of the FREEE energy is to benefit ALL. That's is my mind energy too.
For some reason, when you go against someone, you should know their truth. Which should make you smarter than them. But then I ask myself, can you even repair a dishwasher?
Please answer me with step by step how to repair a dishwasher from a 360* angle way of looking at every dishwasher problem.
It is pretty simple that laws change....if you look at history 100% facts. So it is kind of ignorant to believe that laws will never change!!!!
All laws have 10% of the truth and 90% of wiggle room. This is essential to "evolve". I already mentioned that none can survive that long being 90% happy. Or making 90% money all of the time. That's will violate the laws of life! You actually don't have to be that smart to understand death!
Dishwashers are fairly well built and dependable these days.  Most of the problems I have seen is a clogged water inlet valve, which is easily repaired by cleaning.  I did repair one where the motor cooling fan blade had come loose from the shaft where the weld had broken.  It was easily repaired with some JB weld and is still working fine 4 years later.
I am not sure what this has to do with overunity though.
joel321
QuoteDishwashers are fairly well built and dependable these days.
Yet again another ignorant remark. Jesus crist how can someone be so blinded?
You have to understand how ther market to the consumer. There are three → "entry level" (those that make little money), "middle" (those that make more than make little money), "high end/premium" or whatever your definition to maker to the people that have lots of money to spare.
When you say " Dishwashers are fairly well built and dependable these days" you are basically just ignoring the other angles of viewing at things.
The fact is that the more the earth's resources are lacking, the more the items are less lasting. Meaning, the closer we get to the non-abundance, the weaker the item is. If I can't explain myself, I mean, if you have little resources, the less quality it will be.
Ok, show me facts that " Dishwashers are fairly well built and dependable these days"...with actual statistics? Since I'm sure that you stated that from the statistics!
QuoteMost of the problems I have seen is a clogged water inlet valve, which is easily repaired by cleaning.
Ohhh, I didn't know you where an appliance repair man?
Ohhh, do you understand the facts behind why the clogs happen?
QuoteI did repair one where the motor cooling fan blade had come loose from the shaft where the weld had broken.
ohhhh, you only have repaired one? And just based on repairing one shows you understand the degrading of machines today in the big picture of understanding the degrading of machines?
Ohhhh, ok! Was that a brushless motor you repaired?
You are proud of fixing induction welds that failed?
Ohhh, 99.9% of the dishwasher that fail are from clogs and/or from fan blde becoming loose?
QuoteIt was easily repaired with some JB weld and is still working fine 4 years later.
lol, JB weld on metal to metal. That JB weld is actually weaker than induction welding and induction welding is weaker than actual metal to metal welding with more heated metal. This goes to show how you are not knowledgeable about welding either.
QuoteI am not sure what this has to do with overunity though.
I'm not sure why you with 6643 posts here understand much at all.
I already said, to understand a lot of things it is simple as to fixing a dishwasher=understanding how it works.
JB welding a motor is not the same as looking at how it works from a 360* angle. And the same applies to "overunity" you have to look at it from a 360+ angle to fix and understand every angle!
Your JB weld is only looking at it from a 2* angle. Not 360* or 100% all angles.  8)
Pirate88179
Whatever dude.
I had a dishwasher break down...i fixed it.  Several friends asked me to fix theirs...I did...end of story.  You are the one that claimed I could not even fix a dishwasher so, I gave evidence to the contrary. I am sorry that you could not handle it.
Can you make a ceramic spring?  Specifically, one out of partially stabilized, transformation toughened zirconium oxide?  I can, and I did.  It flew on the Space Shuttle STS 60.
joel321
QuoteI had a dishwasher break down...i fixed it.
yes I understand but you ONLY fixed it from one angle! I don't mean to not give you the appreciation that you deserve for fixing it, but that is still from one angle. You have to understand about the engineers to whom "designed" the dishwasher too. They also need criticizing and credit!
QuoteSeveral friends asked me to fix theirs...I did...end of story.
The story never ends! Nor does learning nor evolution. Now does life! With all due respect, your "evidence" does not imply that you have ever created a dishwasher. And since you have never created one, you cannot even speak about one and be 100% correct about ow it works.
QuoteYou are the one that claimed I could not even fix a dishwasher so, I gave evidence to the contrary. I am sorry that you could not handle it.
yes you fixed one by unclogging them and JB welding the motor fan...but there is more to understand how they work and more to understand how they fail. IOW, your friends are not enough to understand the WHOLE dishwasher problem situation. This is simple to see. So you are only replying to me that you see 360* dishwasher problems based on you repairing your friends dishwashers! That is not enough. You need world wide statistics to give close to 100% facts!
QuoteCan you make a ceramic spring?  Specifically, one out of partially stabilized, transformation toughened zirconium oxide?  I can, and I did.  It flew on the Space Shuttle STS 60.
Well, I have not, but using dishwasher components can I make one?
