e2matrix
Quote from: jbignes5 on April 17, 2014, 12:11:18 AM
Are you saying you built it or taking numbers out of context from the link you posted?
Agree.  Nowhere in the pdf did it say they were using 1KW input on that situation.   But another quote from the pdf : "-we are about a day and 1/2 from having a self-running QEG in Taiwan - we'll have a video after that. "
I'd give 'em 5 days.
woopy
Hi Wattsup
thank's for your input.
I tried your proposal as to close one leg of the 2 opposite U cores and let pass the alu rotor only on the other side. It work also but seems not better than when it cross the 2 cores as per my video. Than i put a magnet between one end of the core , but by simply passing the alu rotor i clearly feel the braking due to Eddy currents, so it will change the basis of the aim of this experiment.
Than i redo the montage with one core/coil as per my first video, (for info, when dismantled, i have checked the magnetism with a compass to be sure there is no residual magnetism in the core ) and i tried to accelerate the rotor
. I have got ,  good result and resonnace tuning, but above 3500 rpm , my rotor began to unbalance , and knocked the core and game over.
So for me this experiment was just to check the variation of inductance and the effect. But i will stop here and wait for further result from the QEG people, if any.
Anyway very interesting stuff, once more, to improve my knowledge.
Good luck to you and all
Laurent
shinz62
Quote from: e2matrix on April 17, 2014, 12:31:56 PM
True there was no mention of the input wattage, however, that PDF was dated April 4th... it has already been 13 days and counting.
-- Somewhere in the discussion it was mentioned that the machine had to be "re-tuned" each time it is moved. This lends credence to the idea that the earths magnetic fields are influencing the machine in some significant way.[size=78%] [/size]
jbignes5
What does the Q mean in QED?
Lets look at a very long series on what is currently being seen and the new revelations of what it means...
https://www.youtube.com/watch?v=W7UOCw-FsIc
This is a 6 part series. Please watch it all to fully understand what is being understood and how they are proving it.
And I will back out of this discussion. There is a lot being discovered and what is being discovered is a lot of flim flam to make things work with our current models. This is an exciting time to be alive as we start proving the old entrenched theories wrong or skewed. Now it is up to us to admit that we could be wrong and have the courage to put it right.
I doubt some would even take the time to really understand this video series. Those people are sheeple. They are taught from day one to obey and not question. They will not go along till there is a real device to prove it. They are not my and others concern. Who is our concern are the ones who want the truth or as near as we can see the truth. You want to know what it is all about then watch the whole series of videos. Thank you for your time.
May the Universe bless you all with abundance,
jbignes5
Wattsup:
This is off topic but it is worth mentioning.
I am not sure what effect you are referring to for the Rodin coil?  A vortex?
Look, you know what the magnetic field is like around a very long straight wire carrying DC current, right?  You know that a shorter length of straight wire will have approximately the same magnetic field pattern.  You know that the magnetic field at any point in space is represented by a vector.  You know how vectors add together.
So why can't you just crunch this in your head?  Let's look at a "Rodin starship" coil, because it ties directly into what I said above.  The starship coil is just a bunch of straight lengths of wire.  Visualize the field from each wire, and add them all together as a vector addition in your head.  You visualize how on the outer "points" there is quite a bot of vector cancellation.   When you back up a bit and look at it from further away, what do you have?
The answer is just a lousy version of a regular cylindrical coil.  You use more wire to get the same inductance, and there is a lot of useless magnetic vector cancellation.  The Rodin starship coil will always be beat out by a regular coil.
What about a vortex?  When you do the vector addition in your head, do you get a vortex or not?
