MarkE
isim
Last news from skype QEGNetwork chat room for "Information":
[06/05/2015 09:40:16 | Modifié (09:44:08)] MMeta200: A New HopeGirl Blog post...remember 1=2, 2=4? Now we have the square of the forces...3 x 3 = 9 next, the cube of the forces.....Read on.........
[06/05/2015 09:41:08] MMeta200:  New post on HOPEGIRL BLOG
QEG GREECE! Introducing Odyssevs Ellas
by hopegirl2012
QEG GreeceWith amazing resourcefulness, and a passion like we've never seen, The Odyssevs project in Ellas Greece is building their QEG from the ground up with an impeccable level of care and higher consciousness.
Odyssevs is a group of currently sixteen simple residents of Chania Crete and two from Athens plus a humanitarian group called Peace Farm, for a total of nineteen members. Their goal is to "return home".
In this amazing video, you see pictures of family members with QEG parts on the beach, blessing the stators with sand and sea. They machined just about everything on their own, including an incredible toroidal winder made out of spare machine parts and a bicycle wheel!
Video of the Odyssevs handmade toroidal winder made from spare mechanical parts and a bicycle wheel!
The Ellenic Theory
An excerpt from QEG Greece Odyssevs from their be-do.com profile found here: http://be-do.com/index.php/en/forum/ellas/566-qeg-our-ellenik-theory
QEG does not break the laws of nature by achieving over-unity on the contrary
exploits the rules of nature during the phenomenon of resonance on earthquake.
All the words, letters and punctuation marks maybe mine but the theory may
not belong to me but nature.
Our goal is to make something very simple and important with consciousness.
Is touching to be asked by children how QEG works?
Do you know why the buildings collapse on earthquake? Yes, because they are
not strong enough! Yes they collapse because they can only withstand 1000 kg
i.e. the weight of a car. Now when the earth is shaking right and left for
about 10 times per second also the building is shaking. Well then we will use
all the sciences of the Elleniks (E=λ*λ*A*Ω) or E=C2m in order to understand
what happens. Do you know how many are the Sciences of the Elleniks? Yes,
they are Four! Arithmetic, Geography, Astronomy and Music!
We know in music when two instruments or violins are playing that we are not
using Arithmetic because one plus one is not two in Music while in harmony.
Instead we are using the number of instruments by itself or in the square.
For example when two violins are playing in harmony it is like four violins playing.
When two children are screaming in unison is like you have four screaming children.
When they are three screaming children sound like nine. So then when the earth
shakes by a force of 1000 Kg reaches resonance with the building which is also
shaking with the same frequency vibration.
Then we have two resultant forces of similar magnitude which means arithmetically
we have not 2000 kg of force but Musically we have four 4000 Kg. In other words
during the resonance of earthquake the building is subjected to the force of the
weight of four cars on top of it. This is the reason why the building collapses.
Now back to the QEG the role of the earth is performed by the rotor which is
transferring the vibration to the building which is the core made out of steel to be
strong and enduring to vibration. When the rotor and the stator reach resonance
we have the phenomenon of earthquake and strong forces flow through the core.
Now you can understand why the core is not square like a building. Because we
want these huge forces to close circuit so that we can collect them. Otherwise the
core would be destroyed just as on the earthquake.
Now you understand how the QEG core was designed by using Geometry. Now you
know in order to collect the flow of the electric current we use the isolated enameled
copper wire. Not only we collect the current but we create a third construction like
a third building. This time electric not just physical, by using the coil and a capacitor.
The rotor is used as a switch producing the electrical vibration to the coil and the
capacitor. Opening and closing likewise as the rotor transfers the physical vibration
to the core. So with simple Arithmetic we have three buildings all in resonance so
Musically 3x3=9. In other words if we use 1KW of power in the input we can have
9 KW of power in the output.
Now ask where is the fourth science of the Elleniks, Astronomy used? Well astronomy
does not mean Astrografy i.e. to know where the stars are. But its important to know
what the word Astronomy means. It stems from the word Sterile with a prefix A or Non
in Ellenik and since Nomos means rule Astronomy becomes the Rule of Non-Sterile source.
The theory I wrote in August about the QEG can be verified in this document,
Trans-Verter research and development.
"Overview of Operation
Standard AC transformers can be pulsed to a measurable Over Unity transformation condition
where conventionally the readings are not yet investigated or understood. Theses readings
and efficiency states are achieved by taking the AC transformer into resonance. The power
within the LC is interpreted from the inventor Hector as radiant in nature and provides a
source of 'imaginary' potential within the shift of the resulting power factor. The research
and development potential is to extract this potential in a condition that is non-linear and
reflected to the source."
Here is the document:
www.panacea-bocaf.org/files/Trans-verter%20R%20and%20D.pdf
Here is Tesla original copy TESLABOOK.pdf also Tesla verifies QEG operation:
docs.google.com/file/d/0B2rSroUC8bsDQzVBUVR2YTFlV3M/edit?pli=1
Γιώργος Κονταράκης
hopegirl2012 | May 5, 2015 at 12:00 pm | Categories: QEG | URL: http://wp.me/p2Gy1r-1ef
[01:28:29] Alexander Bell: https://www.youtube.com/watch?t=919&v=DMRLDFChjtc
Enjoy... :)
QuoteStandard AC transformers can be pulsed to a measurable Over Unity transformation condition
100% nonsense.
