0 Members and 43 Guests are viewing this topic.
SoManyWires
some do seem to know their greedy stuff, and sadly that is their prime motivator.
the ones that blatently try to rip people off using profitable lies are the worst of property value decreasing slime. and they know it.
such as malignant degenerative sociopaths or worse.
stivep
Quote from: joel321 on September 02, 2015, 11:26:55 PM
Stivep,
Everything that you are telling me seems like you do agree with me but at the same time you disagree with me hehehe.
We discussed so many other things
in some of them  we agree - yes.
But  what I'm telling you is that light does not bend.
Like bending of light – somehow you are trying to tell me that light cannot bend while at the same time you give me answers that suggest that light does bend.
Quote from: joel321 on September 02, 2015, 11:26:55 PM[/size]
IF you think about a laser beam, say, 3mm wide, are not the photons inside the 3mm laser beam bouncing around?
Or ARE ALL photons in the laser going 100% straight in all directions?
All of the photons go  in the straight  direction.
If the photons bounce around a light beam, that means that light bends period.
Photons can not bounce all around beam. If you are photon  you can not bounce around yourself.
Photons can not  sense presence of another photon. they do not "see" other photons
Photons can not share energy with another photons
All known human mater bends...rocks, air, glass, plastic, diamonds, human bones, etc bend...ALL matter has a percentage how much they can bend but they all BEND!
Photons are not matter,
photons do not have mass.
photons are just energy pockets
in the free space photons have fixed speed= speed of light
It just has too since a photon has to pass through a lot of sub atomic particles. Like,
for example, a light beam going through glass, the clear glass is made of sub atomic particles,
so it has density to keep it's structure...if a photon just goes 100% STRAIGHT
through a piece of glass, how can the photon go through it straight if the glass gas mass?
It is explained by   probability of collision.
certain photons do interact with that  particular matter or with subatomic particles of that matter, but they must meet criteria of that interactions  while other  photons do not.
one of properties of photon is frequency, as photon is electromagnetic wave.
the higher is  photon frequency the bigger is  photon energy.
Photons of x-ray have lower  frequency than gamma.
Photons of x-ray easily interact with orbital electrons
Photons of X-ray brakes nuclear bonds.
Photons of  visible light  "can do no harm"
Photons of  UV light  "can do  harm" but  can not brake nuclear bonds.
Photons of visible light differ between themselves too as visible light is term  assigned to
all colors and each color  represents photons of different frequencies.
To easier understand it:
that what is impossible to be penetrated for photons of visible light , is easily penetrable for photon of x-ray.
this one might be little difficult to you
Interactions of Photons with Matter
http://ocw.mit.edu/courses/nuclear-engineering/22-01-introduction-to-ionizing-radiation-fall-2006/lecture-notes/energy_dep_photo.pdf
but
this  one will not be difficult to you:
http://www.sprawls.org/ppmi2/INTERACT/
Photons of gamma  are results of previous atomic instability
e.g.  when number of neutrons and protons in nucleus  is uneven, than  given atom of given periodic table component may not be able to hold that ,
than matter and/or  energy is  being ejected from  nucleus.
Photons:
you take  Chinese from China , African  from Zambia and American from USA.
all of then are humans
But they can not interact between them-self as they are in different continents.
They look alike but they are different, shape height weight and so on.
Photons also  have factors  characteristic to photons :
e.g. frequency, and energy level
Photons energy level, isproportional to frequency ( per period)
(period is  equal to one cycle)
http://web.pdx.edu/~emch/rs/vh1.html
the easiest  way to understand photon is th  say  photons are weightless  energy carriers
Now think how light CANNOT go thought a solid object while sound WAVES CAN!
sound wave is longitudinal ( pressure wave)
Electromagnetic  Wave is longitudinal and is not seen as pressure wave, however
you may find term "electromagnetic pressure"  in physics.
for simplicity we are skip this property  as it is not important as a factor.
QuoteSound is a Pressure Wave. Sound is a mechanical wave that results from the back and forth vibration of the particles of
the medium through which the sound-wave is moving.
sound wave can  move mass  without any conversion , while electromagnetic wave can not.
{ unless is converted to  another form of energy (e.g heat) but that  you will not deal with EM any-longer.}
The two  types  of  waves  have  common descriptor "wave". other than that  they are  different so much
that " they can not communicate" and they can not be compared to "serve" our  discussion,
If you think about the sun producing light, why is the ball of light 360 degrees and not a square? :P
that has nothing to do with photon and it belongs to different group  of subjects discussed.It takes me to much time to go there and explain it.
You also have to think in the math and in the brain how black holes BEND LIGHT too.
But you also have to ask yourself WHAT CREATES BLACK HOLES? And where are the sound waves around the sun?
we spoke about it  already
WHAT CREATES A PHOTON? And does a PHOTON by itself glow in the middle of darkness? IOW, there are no photons in dark spaces?
https://en.wikipedia.org/wiki/Photon
It is the force carrier for the electromagnetic force
if there is nothing to carry on, than there is no  photon needed.
like no "wrap" for that package if there is no that particular  package.
So that means an over-unity device exists INSIDE the earth, but outside the universe since the universe is
more COP>+ than the earths COP>+...
I mean how does energy work COP←.....that's just 100% truth. There is a COP>+ in order to keep on living via the GIVEN resources
(returnables) from the earth.
Many people, just want to "debate" about their two cents BUT the truth is always there :)
...the truth has road blocks too just like a photon does too?
overunity  OU does not exist and never existed
however  for  eye candy it looks like  it exists.
QuoteWikipedia:
eye can·dy
noun
informal
visual images that are superficially attractive and entertaining but intellectually undemanding.
Explanation:
Contribution of  factors that are not noticeable  by our sensory sensors ( eye)
can make something looking like  OU.
there always  will be conversion of energy.
For us OU is only explanation  that says that we ate getting energy that does not have to be paid for.
like opening the valve of the water pipe that has no  taxable  energy source.
So say we have river and we have pipe  one end in that river.
At the and of that pipe there is valve .
energy needed to open  the valve is  small but than it gives us access to energy of water flow.
That energy is our overunity OU, comparing to energy used to open the valve.
another  example of OU is when you have 1 dollar in your packet and someone  gives you 100 dollars .
Your packet would not know what made it to  have  so much over that unity of one.
And there are plenty of ways to get that OU.
that is why I"m here.
Wesley
joel321
QuoteBut  what I'm telling you is that light does not bend.
This cannot be true based on all that we know so far. The 100% fact is light curves inside a curved string of glass or a curved string of clear plastic (like I mentioned the optic cable). How does the optic cable is able to bend the light beam? Now think about it for a second, or for a few days, do you actually believe that there are no "optic cables" in the galaxy...from the acquired knowledge that I have gained, most likely the human just copied it from mother nature. One sometimes believes that humans "invent" something when it is just a lie, they don't INVENT anything, they just LEARN from what they see.
How are you 100% sure that light does not bend in space? You do understand perception right? If you look up at a star, it looks like it is "glowing" like if it is blinking...that right there means light bends. Now show me a powerful laser beam (abiding by the legal standards) pointed in to the sky and then measure the curvature of it by taking a picture of it from another planet... wait a minute, this is why the galaxy looks like its swirling. Light DISIPATES all around.....as a mater of fact light is like a sound wave...the ONLY reason a laser beam goes straight is because MIRRORS are used to FOCUS the intensity towards one area but this is the same like speakers, WiFi antennas, etc. light does BEND period LETS NOT CONFUSE IT WITH the speed. I'm not talking about the speed.
QuotePhotons of x-ray have lower  frequency than gamma.
What instruments did you use to see a photon? Or to even name such particle as a photon? From where does the name "photon" derived from (someone had to give it a name)? Do photons die? Or do they keep going in a "straight" line for ever?
I just want to understand how you are able to see photons with your eyeball and some tools. HECKK! How does a photon look like in an oscilloscope?
The way I see x-ray is like this https://youtu.be/cf3WJM72sYs which is just a way to close microscopic windows. The opposite of looking at bones in the skin, is to "open" the windows of flesh. The same can be said about ultrasound on a female looking at the baby fetus.
QuoteThe two  types  of  waves  have  common descriptor "wave". other than that  they are  different so much
hehehehe you are the master of all known waves. And you know 100% with out a doubt that sounds waves do not communicate with light waves just because you said it.= lol just another guy passing by on his high horse.
Quotethat has nothing to do with photon and it belongs to different group  of subjects discussed.It takes me to much time to go there and explain it.
All the energy you may give does not = 100% of your energy given = 100% truth...you can spend your whole life explaining but that does not mean it is 100% true. So I would love to know the story behind how you came about learning about the photon!? Give me the whole story since a little baby till your current current age. Also, mention the tool you used to understand a photon 'cause I love tools myself...anything having to do with a measuring tool...Plus, give me a microscopic picture of how a photon looks?
Quoteoverunity  OU does not exist and never existed
If a hooker in the streets tells you that she loves you, will you believe her? = don't take the UO LITERALLY. OU just = COP>+. You can replace the letters with anything else but the evidence CANNOT change. If you could give the SUN a name regarding a battery, what name would you giver it that it would make sense if you wanted to buy a very long lasting battery?
I think people are taking OU, QEG too literally and not using their brains to predict the outcome/truth lol Why would a poor person believe in OU? Why would a rich person believe in OU? Even if the Over Unity name changes, the truth REMAINS THE SAME! lol
Pirate88179
Joel:
Even JB Weld can not make light bend.  It can do a lot of things but....not that.
Why is this so hard for you to understand this?  A laser is a coherent light beam.  It does not bend nor diverge (within the parameters of the laser) which is why it is so useful in so many applications.  You should read some books on this...it really is a beautiful invention.  Yes, it was invented at Bell Labs.
SoManyWires
rich, poor, it doesn't matter who a scammer takes money from, just as long as they can.
there is no trust in scammers.
some of them have nice stereo speakers even.
