joel321
QuoteFrom the perspective of a photon, there is no such thing as time.
This is 100% wrong. 1st) how do you know what is the DNA code of a photon in the subatomic DNA? 2dn) the photon must experience "time" since it's a rule of phenomena...this is what is wrong with you people = not being open, minded! When you get a cut in your skin, do the white blood cells understand time? They must understand it since the faster they repair the wound, the more probability of success!!!
How is your brain thoughts thinking that photons do not know time? ALL SUBATOMIC particles know time and evolution. The time may not be as your time watching a love movie on a hollyday but they must know time>time never stops! Tic toc tic toc tic toc.
Quotethere's zero time elapsed between when it's emitted and when it's absorbed again.
How do you know this? Show proof in the explanation in the brain or via math?
QuoteIt doesn't experience distance either. Light does not bend it's just an illusion.
Again, how do you know this? Show proof in the explanation in the brain or by math? Let me ask you this, is a photon the same in all the light spectrum?> gamma rays, x-rays, ultraviolet rays, visible light, infrared rays, microwaves rays, radio waves? You are telling me that a "photon" in gamma rays is the same as in x-rays? AND the photon does not EXPERIENCE TIME! Since the gamma rays oscillate at a higher frequency than x-rays?
Again, where is your proof in the mind or in real life scenarios that a light does not bend nor experience time? If light is a "photon" it is both in gamma rays and in infrared rays?  OBVIOURSLY, there is a TIME DELAY BETWEEN both?
Acca
 Your dogmatic programming now is showing nothing original...
Upgrade, as you are out dated ... You are very boring ....
Link for you... http://www.pbs.org/newshour/updates/hawking-meant-black-holes/
"Is not complicated, if a black hole eats light, then it bends. If there are trillions of blacks holes in a grain of sand in out galaxy, light has to bend (or be eaten)...we just can't see it with our eye ball or instruments because we are only judging the spectrum of light that our eye perception can see. If we use our thinking perception, where it has not been mathematically understood, we can see that light must bend if a light laser goes through all of those "black" holes proximity. The same can be said about sound waves."
Wesley has the upper hand in this conversation ....
As well as all the test equipment of some 250 K... got some equipment too....Show it...
scratchrobot
Living cells have DNA a Photon has nothing to do with DNA or white blood cells, your mixing things up!
Don't take it from me but many experiments proof that it works like this.
https://www.youtube.com/watch?v=ZGoDK18b3LE
https://www.youtube.com/watch?v=H6HLjpj4Nt4
https://www.youtube.com/watch?v=NUX6pfXRCLA
joel321
Acca,
Yes I know is hard to understand the galaxy and apply it in terms that make sense from our every day life activities. Like for example, how does acca can understand a light year in comparison to anything else? Even if math says a light year is 186,000 miles, how can you comprehend those miles? How do you even comprehend how many steps an ant takes if it was to walk around the earths equator? You can do the math but the actual comprehension is lacking of the ENERGY involved.
But ok, going back to black holes, do you know how they are calculated acca? Like the actual visual evidence combined with math? Do you know how the planets REALLY revolve around the sun? The sun is moving at thousands of miles per second in the atmosphere (counter or counter clockwise is not know but it is one or the other), faster than the planet earth since the planet rotating around the sun slows it down. Now if all humans in the world where to shine a 40W green laser up in the sky, from an outsiders perspective, the light would look like how the galaxies plasma looks = a swirl. The bending does not even has to do with "black holes" at all...the light bending has to do more with the speed rotation (rotation plus oscillation).
Do this, make a wheel that is 12" wide, attach lasers on it pointing from the center out straight. Then spin the will at 30,000RPM now with a "photon" sensor, measure the time difference the laser hits it at 10,000RPM, 20,000RPM, and 30,00RPM...we can even go to 500,000RPM...the photon laser beam on the sensor will lag = isolate = bend. If all laser beams measure the same at even 100,000RPM them light does not bend BUT if the sensor has a fraction of a second difference between 5,000RPM and 300,000RPM, then this means that light bends.
Light is electromagnetism fields after all? https://i.imgur.com/Lg7PZob.gifv  This actually made me realize that the earths magnetic field SHIELDS the harmful rays from the sun while by the same token, the sun produces sun flares from magnetism....
joel321
QuoteLiving cells have DNA a Photon has nothing to do with DNA or white blood cells, your mixing things up!
I meant "DNA" GLOBALY not just in the blood strands. Once a photon is living, it will experience TIME....in the DNA conscious. They consciousness may be more advance than our brains... HECK! They are the ingredients of our brains consciousness since we can only understand things via electric pulses in the brain.
Just because you cannot comprehend the "photon" "DNA" does not mean that it does not have one...that is just an opinion coming from a person that has "DNA" blood whom may not even know how to repair an A/C (air conditioning unit) system.
The "photon" must experience time weather it likes it or not. NOT in the time we are familiar with 12hr/24hr clock but by a microscopic second compared to our clocks experienced of time. HECK our time is INVISABLE compare to a "photons" time!!!! (hense why our thinking of time is invisable to a phtons wrist watch) a photon passing our clock/time in the Galaxy is more like .000000000000000000000000000000000001 of a second. BUT if we where to be human photons we would "feel" see their time!!! PLEASE TELL ME THAT YOU FEEL THAT YOUR BODY IS GOING ROTATING AT 1000MPH SITTING iN A CHAIR?
