e2matrix
gotoluc,   Thanks for your input and reference to the Ecklin device as it does seem very similar although not identical.
MileHigh,  For a change I find you comments on this enlightening.    I still say though we don't know everything and it is possible some small deviation in how this is built could result in free energy.   But I say just let the QEG guys who are already working on this work this out until they either do or do not have a working device.   If it's not at least putting out twice the power it uses within a year I would consider it a lost cause.   I still do not believe they are trying to scam anyone but maybe they have been duped by the Witt's people into believing it works if the Witts device is bogus.
ariovaldo
Quote from: ariovaldo on April 22, 2014, 09:43:23 AM
This one is hard to build and will take at least 100 hours to finish it, but in my point of view is worthful to try.. Anyway, I'm here to learn and if this generator works, this will be great, if not I'm sure that I'll improve my knowledge...
Cheers
Ariovaldo
One more picture.....
ariovaldo
Quote from: gotoluc on April 22, 2014, 10:09:56 AM
WOW Ariovaldo... you have a lot of courage and patience.
All the best to you in your tests
Luc
You are right about courage an patience, but it is ok.
Thanks
mscoffman
To ariovaldo and other builders,
I would recommend doubling down if you are building this generator by attempting to bring
the machine up in stages. First by using the constructed core to build a 120VAC/240VAC 60Hz
generator that requires a 40VDC static field regulator. You could then find how much power
one can apply before the rotor saturates (see above). Since you are not competing with
anyone (business competitors) there is no compunction to maintain the lowest cost optimality
in the design. In fact you have exceeded the requirements by having a larger winding
wire gauge and you would have excess insulation then required. This would give you
experience with generator field regulation before continuing.
Next build a 60Hz resonant design using the same core hopefully with a not-so-high 60Hz voltage
field regulation. With this you should be able to attain sub-harmonic locking between the field resonance
and the rotor,s angular velocity. Lets one figure out how the rotor energy feeds the field resonance.
Here is the thing. If either of these above works with *high efficiency* one could consider attempting to
build a qmogen motor/generator as a overunity bail-out position. This would be just as good as the Witts solution,
maybe better and you would have all the components to do this as required except you would add an
intermediate flywheel pulley.
Finally attempt to construct the 400Hertz High Voltage resonant field. The generator itself would never
have to be modified, but only its supporting circuitry. This could very well give you the experience required
to find a solution to 400Hz high voltage resonance. It would allow you to experience easy success with a
working project - or to find any design show-stoppers before doing the hard part or having a high voltage
field burn out. This would be one reason to attempt to get the high voltage vacuum formed field core
if at all possible, even though this could actually inhibit the device from overunity operation.
:S:MarkSCoffman
shinz62
F_Brown,
Nice job on the simulation,
Of course you had to scale the current and turns too.
can you say what your primary and secondary numbers are at 400hz?
Thanks.
