0 Members and 91 Guests are viewing this topic.
Marshallin
"Arguing on the internet is like running in the Special Olympics. Even if you win, you're still retarded"
Give it break, device is maybe fake. But idea behind it may be interesting.
We all know that earth produce a lot of energy. We are just too stupid to know how to use it right  now...
Exciter circuit on picture dont give to me much sense. I realy dont thnik right now that spak gap with some induction and capacity can make much positive diference. But i need to do still some tests with spark gaps generaly.
I dont like how much people using word "resonance" ... it almost look like magic. ;)
shinz62
Quote from: F_Brown on April 22, 2014, 06:58:17 PM
I am only using primary windings at the moment because I still have yet to figure out how to attach a load to the secondary in FEMM.  The secondary would just be open ended and generate a voltage without any current flow.
[/font]
You can simulate a load by putting an apposing current in the secondary, you have to play with the current number until you find the most power/current you can reasonable put through without stopping or reversing the flux going through. In the snapshot below I have tried putting 4.5 amps in the secondary and the simulation shows what that does against a .65 amp push from the primary. with zero amp in the secondary the numbers are still interesting because it will tell you how much voltage you can expect to measure across the coil with no load.
[/font]The primary I am using for this is 1550 turns of 20awg wire, which is 1/2 the turns of the original 3100.  I set the current at 0.9 amps and raised the frequency of operation to 1kHz to prevent saturating the core.  That is maintaining the flux density under 1.5 Tesla's for the M19 silicon steel laminations.  This type of core is usually only driven to 1.0 T to 1.5 T because the material saturates at around 2 T.  If the core saturates, it would allow large current surges to propagate though the windings and cause bad things to happen.  I set the gap between the stator and rotor at 0.025".
What "bad things" might happen if the core saturates (at any particular frequency)?
The numbers I am interested in are the from the Circuit Properties Results for the Primary:
Voltage Drop
Flux Linkage
Flux/Current
Voltage/Current
Real Power
Reactive Power
Apparent Power
[size=78%]
[/size]
[size=78%] [/size]
At the moment I am preparing an animation of the flux density during a full rotation of the armature.
Great! I saw the animation, it is interesting to watch.
May I suggest that you should standardize the color scale for the flux density plot so that it is easier to tell what is actually going on. Otherwise femm will re-scale each frame and that is why you get the flashing color effects. It is also helpful to turn on the magnitude vectors plot "->" (B_re) which will show you north and south and provide additional information as to the strength of the flux.
I'm now wondering how this compares to the actual configuration of SEG since both your model and now mine has a double wide rotor compared to the posted SEG drawing. I would really love to see a scope shot of the WITTS/Trapp prototype QEG output voltage and current under load.
Here is my update, I have slimmed down the main core to 3/4 " and left the rotor at 1 1/2", its original size. It has the .026 diameter gap as described, which is a radius of .013. It has the same number of turns 3100. With the full size core it would look very differently (probably have much less ability to sustain the secondary current) so I don't know if there are any conclusions that can be drawn from this analysis compared to the WITTS prototype QEG.
I have to admit I still don't see how the QEG can work good maybe it doesn't. When you look carefully at the Trapp video you can't really tell if the rotor dimensions are 2:1 like this, or 1:1 like the plans that were posted.
One thing for sure, WITTS/Trapp talks like a Christian free energy evangelist that wants to bring their technology to the world, but acts like every other greedy inventor, because for one thing, they will only "give" out their information and "free licensing to build up to 3 devices" after a required minimum "donation" has been made and they still claim they are not "selling" anything, what a farce.
Here with a simulated load of 4.5 amps at 400hz numbers:
Primary:
Total current = 0.65 Amps
Voltage Drop = 2923.19+I*25197.2 Volts
Flux Linkage = 10.0256-I*1.15361 Webers
Flux/Current = 15.4241-I*1.77478 Henries
Voltage/Current = 4497.21+I*38764.9 Ohms
Real Power = 950.036 Watts
Reactive Power = 8189.08 VAr
Apparent Power = 8244 VA
Secondary:
Total current = 4.5 Amps
Voltage Drop = -316.671-I*1567.72 Volts
Flux Linkage = -0.623777+I*0.126728 Webers
Flux/Current = -0.138617+I*0.0281619 Henries
Voltage/Current = -70.3713-I*348.383 Ohms
Real Power = -712.51 Watts
Reactive Power = -3527.38 VAr
Apparent Power = 3598.62 VA
F_Brown
Quote from: shinz62 on April 23, 2014, 03:32:40 PM
I'll have to try that.
As I mentioned current surges.  When a core goes into saturation the control of the current flow by core inductance is lost, and the transformer then starts acting like an air core transformer with much less inductance.  That loss of inductance mean a loss of current control.  When the current is allow to surge it can over heat the windings and cause insulation failure.  When the insulation fails, the coil shorts out either between turns or to the core.  Over heating can also cause the varnish on the transformer if any to burn etc.
Voltage Drop
Flux Linkage
Flux/Current
Voltage/Current
Real Power
Reactive Power
Apparent Power
Yeah, I'm already on that.  I am also making finer steps between images.  There will now be 144 separate images per rotation.
Yes.  It's frustrating that Hope Girl is talking too much, and James is talking too little.  There is another video posted yesterday or the day before that provides a few more tidbits from James, although sound, comprehensive stats and scope shots still have yet to be forthcoming.  However In the latest vid James does talk a little about using a scope to tune the QEG.
As transformers go the general rule of thumb is that the lamination stack height to the center tongue width in standard EI cores, which is what the rotor in this case equates too, can be anywhere from 1:1 to 2:1.  So, there is room for adjustment as needed there.
Primary:
Secondary:
Excellent!
I'll get some numbers up when I finish the second animation.
Cheers,
FB
PS  The dimensions of the QEG core are probably the WITTS dimensions verbatim.  In the Skype chat video or the audio only video from Morocco, James talks about how the rewinding of the Taiwan core after the primary failure resulted in the surface of one of the rewound primaries with interlayer insulation being too close to the rotor.  By thinning the stator by moving the inside surface of the stator laminations that holds the windings farther to the outside, that problem is alleviated.
dieter
Now, after my rant against NSA and/or energy industrial complex stalkers (actually the two are a team anyway), totally coincedently I just received a PM. After several weeks of no interest, suddently somebody want to buy 150g of my gadolinium (see marketplace section).
The user has just opened an account, has zero postings. Am I paranoid when I smell a dead fish here?
That's how it works. They identify you, put you on a dead list, then you'll lose everything: job, home, friends, and most targets die soon after.
The slave planet, run by the pseudohumans is truely a fashist state.
You are a real hoot Dieter.  Can't you imagine the headlines on cnn.com, "Pulse Motor Enthusiast Threatens Military-Industrial Complex."
Meanwhile, back in the real world from Sean with the big Karma:
http://be-do.com/index.php/en/forum/qeg-general-topics/278-resonance-question-self-running-video?start=6
QuoteJust to be clear to the so-called ´healthy skeptics´ amongst you
This forum supports those who strongly resonate with the impression that the QEG, and the technology involved,  requires more than just an engineer's degree and logical mechanical thinking to make her work.
On the one hand the QEG is indeed a machine, but a totally different kind of machine than the ones we are so familiar with. It is true that she may need a skilled technician to build her, but truly requires a shift in consciousness to understand what makes her ´tick´. And that´s where one´s attitude in this whole process can and will make a difference....
Take for example the "double-slit experiment," where the mere act of ´observation´ can completely change the outcome of an event. There are a number of things so far, involving the measurable part of the QEG, which currently may not make any sense... but then perhaps it needs a different level of sensitivity all together. Your presence, your state of mind, your attitude are believed to be key ingredients in observing the successful creation of this free energy device. This forum supports that belief and vision.
In short: There is no place for skepticism in this forum, you won´t get far trying to court a lady with skepticism, cause truly that is what the QEG is, a Lady with a mind and a will of her own.
So, having said that, I am sure there are those who do not agree with the rules and guidelines of the forum, which is fine but I suggest to then find another place to continue your discussions.
The forum moderators already have spent a lot of time and care in explaining to individuals why certain posts do not resonate with the forum rules, which is respectful but at same time to be honest I think they have better things to do with their time. Therefor please note that the decision to edit or remove a post is up to the moderators and not users, moderation doesn´t need further explanation and their decision is not open for debate.
Thank you
Instead, they should make it a crime to make thoughtcrime a crime.  Think of all the possibilities that would open up like the petals of the Flower of Knowledge ushering in a new age.
