mscoffman
What I would do is take a spare QEG generator core as a temp. step down transformer 7:1 to step-down between the field
coils to the main coils. 120VAC / 7 = 17.1VAC. Use a bridge rectifier to rectify that signal and put some DC Electrolytic filter
capacitors on it. Now feed resultant 20VDC or whatever into a 12VDC->24VDC inverter 120VAC output hopefully 2KW max
hopefully sine-wave inverter Then plug the variac from the motor and a 1000Watt room heater load into the inverter. No
waste stabilization incandescent lamps. Plug variac and heater through two x Kilawatt Meters.
Show us the numbers from two Kilawatt meters the demonstrate current overunity energy production levels.
Then let control experts develop a controller for your resonant generator for you to stabilize it.
:S:MarkSCoffman
SeaMonkey
Resonance may not be absolutely essential.
Zimmerman's generator has uncanny similarities
and is capable of operating with permanent
magnets.
Magnetic Field Reversals at the Output Coils
are easily accomplished.
At this point I'm pretty convinced that when they see resonance they believe that a lot of excess power can be extracted from the system.  The problem has been explained many times now, the very high voltages and currents just represent stored reactive energy, i.e.; the storage of a fixed and relatively small amount of energy in an LC resonator.  To sustain the resonance, the power bleed off is balanced by the power addition, and that's even before you try to connect a load.  The clue that they (possibly) have no idea what they are doing is in the "surprise" that the coils are causing a dielectric breakdown and they have to use some fancy vacuum potting procedure.  That's because nobody would normally operate output coils like this, you are literally defeating the purpose of the output coils if you operate  them at their self-resonant frequency.  You actually want to stay away from the self-resonant frequency so they operate properly and produce output power (provided by some _other_ power source, like a magnet passing a coil and experiencing Lenz drag if and only if the coil is driving a load.)
So the whole thing is just a fake-out due to ignorance and/or stupidity and/or to con people out of money.
There isn't much more to say as far as I am concerned, but it will be fascinating to see how this one plays out because there is a lot of money on the table, and a lot of it is "new money" from New Agers and the like that are not used to seeing this thing happening.
And I know that there are many OU forum regulars that won't believe me and refuse to even acknowledge this explanation for what's happening.  They steadfastly believe in some sort of "magic" associated with resonance or they believe that this setup is truly a portal to "quantum energy" directly or indirectly due to the resonance.
Just watch the story play itself out.  Since the QEG team clearly doesn't understand what electrical resonance actually is and what it means (or that's what they are pretending), it's going to be a bumpy ride.
P.S.:  The notion that you have to believe that it's going to work to make it work is hogwash.  The poor African mother waiting for a QEG to power her water pump so she doesn't have to walk 10 kilometers to get potable water doesn't care about that New Age nonsense.  She just wants the pump to pump water and the power source to provide power to the pump, period.
How do you get to Carnegie Hall and Nirvana?
Measurements, measurements, measurements.
People like HopeGirl, James M Robitaille, Wayne Travis, James Kwok, John Bedini, Peter Lindemann, the Mighty but Tiny engine guy, and a long host of aspiring free energy performers need to get this into their heads.
F_Brown
I've made some progress in understanding how the QEG works by creating a SPICE model that simulates the parametric excitation and resonance.   Here some images from my simulation.
It's interesting to note that this is only for one half of the QEG primary.  Both halves combined would double the output calculated here.
I also have realized what the exciter coils do.  They inject noise into the system to give the parametric pumping more to work with.  Although I wonder if that actually adds anything since so much current is already resonating in the tank circuit by then.
For me, there is only one question left...
How much input power does it take to do this?
