0 Members and 58 Guests are viewing this topic.
IBreal
A few days ago I was banned from the QEG Forum when my first post, which is quoted below, was submitted to the moderator for approval.  They must keep track of the computer it came from because another member of the same household which was a QEG Forum member and had received thanks from other members was also banned at the same time.  Since my reasonable post was blocked and got me banned I decided I would publicly post it here so that others who are objectively doing their QEG due diligence are aware that the QEG Forum moderators are not being objective and are NOT following their own QEG Forum Rules & Guidelines by blocking this type of post.
QEG Forum moderators banned me for attempting to start a new QEG Construction thread and post the following:
QuoteNew Thread Title: Reasonable Questions/Concerns About QEG Claims and Operation
REQUIREMENT quoted directly from the QEG User Manual 3/25/14:
"The QEG is an electromechanical device and as such, safety for the individual and end user should always be of prime concern.  It is therefore essential that persons assembling the device are experienced in the field of electro-mechanical assembly.  A considerable level of knowledge in quantum physics is also required."
"It is imperative to understand YOU NEED PROFESSIONALS AND EXPERT ADVICE to build a QEG."
As stated in the QEG Users Manual in the above quotes and by James Robitaille, engineers and technical expertise will be required to co-develop, build, tune and install the QEG.  Technical members are needed to improve and/or solve the challenging technical problems that will need to be analyzed and resolved so that the QEG can be efficiently built and implemented to operate safely and reliably. The reasonable questions/concerns that are being raised are due to the claims made by James Robitaille and others from FTW about a free energy 10,000 watt QEG that can power a home, but raising these questions/concerns is starting to be discouraged in the QEG Forum Construction threads.
Raising common sense questions and making fact based comments is part of doing one's due diligence before spending money or time on anything that could be very time consuming and costly.  Doing one's due diligence does not make one a naysayer or troll and should not be hastily dismissed as bringing 'negative force'.  No one with good common sense would buy something As-Is from someone they did not know without first asking questions and confirming it worked, this would apply even more so if it involved new/unproven technology like is claimed with the QEG.
Successful technology is not based on faith, it is a major technical undertaking.  Those that make the claim have the burden of proof.  James Robitaille and anyone from FTW (or WITTS) can not reasonably expect that no skeptical questions will be asked before money and/or time is spent on unproven technology.  Reasonable questions should be expected until claims are proven.
CLAIM directly quoted from the QEG User Manual 3/25/14:
In the QEG, input power is used only to maintain resonance in the core, which uses a small fraction of the output power (under 1000 watts to produce 10,000 watts), and once running, the QEG provides this power to its own 1 horsepower motor. This is known as over-unity. Once the machine builds up to the resonant frequency, it powers itself (self-running).
From technical perspective here are just 5 factual challenges for the QEG thus far:
1. James R has not demonstrated a verifiable self running QEG, he stated in the Taiwan video that back home he had tried to manually switch the QEG output power to the DC motor but could not get it to self run.  He stated in the PESN video that he didn't have an inverter and thinks an inverter should provide the hold time needed during the switch over in order to get it to self run.  This was not accomplished at home or Taiwan, next attempt will be made in Morocco.
2. James R has not provided voltage, current, power or waveform measurement data for a running QEG, regardless of the reason it was not provided, this is critical data that would greatly help and needed by technical members.
3. James R reported that he called Torelco to stop production of the processed QEG cores until the high voltage arcing that damaged the QEG core windings in Taiwan could be resolved.
4. James R reported in his last video from Taiwan that while there he realized that the QEG needs to operate  at a higher output voltage which will change the QEG design again, he has already mentioned changes involving: secondary spark gap, interlayer insulation, vacuum impregnated windings, secondary wire gauge and number of windings, capacitance, inductance, RPM, and using higher voltage inverter or step-down transformer.
5. James R is still trying to figure out how the QEG works based on his own comments, others are being trained on a QEG that is not fully understood and which has not powered itself.  Morocco will be the third attempt location.
The QEG Forum Rules & Guidelines state that you're looking for people with constructive feedback and honest questions. That's what my post is about, reasonable questions are justified based on the QEG claims and the above facts alone.  If technical members are discouraged or prevented from raising reasonable questions and concerns the QEG will primarily become a faith based venture that will head in the same direction as the numerous free energy claims of the past.  With the New Paradigm Business Model being promoted for the QEG, it especially does not make sense from a good project management perspective to start to build the QEG before analyzing and addressing these types of questions and concerns which could potentially SAVE many members a great deal of TIME and MONEY.
F_Brown
I would add to that something that I have yet to see explicitly mentioned anywhere, and that is by all accounts, regardless if the device operates under-unity or over-unity, there is a lethal combinations of voltages and currents present in the device when it is operating.
All would be experimenters should be aware, that they are taking their life in their hands just being within arms reach of the QEG when it's running.
That's absolutely right. The thing is dangerous on several levels. It has the rapid rotating part that experiences asymmetric loads. It has the bank of capacitors charged up to multi kilovolts. It has a relatively high current capability. That reactive power may not be extractable in a usable constant form but you can bet your bippy it can be discharged all at once into various kinds of short circuits. Capacitors can literally explode, and then _still_ kill you with residual charge in the pieces. Take that reactive power discharge from the caps across your chest and you are dead. Even if you take it from, say, your fingers to your elbow... you will literally cook an arc channel through your meat.
Fourteen years ago I was poking around inside a running dynamotor power supply, and took a discharge into my right thumb at the first knuckle, and out the tip from under the thumbnail. It still hurts and there is a stripe of dead meat under the nail, to this day, and that was a 400 Hz discharge of less than 300 volts.
Quote from: IBreal on April 28, 2014, 10:45:03 PM
(a very reasonable post making excellent points, omitted because it's right up above in the thread.)
You have made an error in your basic assumptions. I think you know what it is, too.
You are assuming that the QEG managers and string pullers are honestly trying to develop Robitaille's dream into a reality, and since Jim at least has some kind of technical education and industrial experience with vacuum cleaner motors, you assume that they would go about the process in a rational and straightforward manner.
However, that is not what is really happening. Do not be distracted by the Red Herrings of resonance, high voltage and great reactive power readings. This whole thing is about the Almighty Dollar Bill. The longer and harder it is to "develop" the device, the more money and the more exciting world travel for the QEG principals. There is also the Messiah factor. Who doesn't want to Save the World and go down in history as the single person who most advanced human culture on the planet? Even greater than Jesus F. Christ, who after all only reaches a third of the world. The QEG will reach every single person on the planet and benefit them all. Right?
So there is a cynical manipulation of "hopeful Messiahs" and it's being used to extract money from the faithful. Who is the cynical manipulator? WhateverGirl. Who is the hopeful Messiah? Robitaille.
Remember: the very best Red Herrings are real fish, and they look like they will be easy to catch. Meanwhile.... YOU are the real fish if you spend any money on this project before Robitaille comes up with a self runner on his own. Don't get eaten.
ACG
@IBreal,
Very good questions.  If you manage to rejoin that forum ask a more simple and less "negative" (hehe) question.
1.  When will the changes be incorporated into the QEG manual released 3-25-2014?
The manual is all about 240v 42A 60hz but the builds are now all about 2kv 5A 400hz (change in narrative the usual smoke screen).
