Hope
Quote from: mscoffman on April 23, 2014, 09:26:23 AM
It's obviously a spark gap. During Tesla's time a spark gap was used to generate broadband low frequency RF.
This was used for exciting in Tesla Coils and as an oscillatory function in radio transmitters (no vac. tubes yet).
What is a spark gap doing tied to power line? - Obviously someone expects there will be static electricity there!
Second the motion by the fact that the sides of the machine are not metal but fiberglass. The metal rotor is insulated.
So it functions like the Testatika machine/Wimshurst machine. Static electricity is generated then is somewhat re-structured
form by adding LF RF to it like in a Tesla coil. and again like the Testatika Power RF Oscillator. These machines need to regauge
(change the relationship of voltage x current to power) so they can isolate subsystems. Then you simply run the re-formed
power through the coils to supercharge the internal magnetic motor flux. Note that electron flux often travels backwards
relative to common current flow.  I've always felt that this machine should operate this way without
knowing the details since the Tharpp video showed it in the first place.  There were previously people that
have done this in the 1920's - once they installed a powerful engine/motor in an aircraft - with obvious outcome. My feeling is that
tribiological electricity is inherently overunity. With three force affecting the electron - electrostatic, electromagnetic, and beta nuclear.
Static electricity is a macroscopic apparition of LENR. I will endeavor to prove this when the Shensei makes their ESM65-TR1
electrostatic motor available for sale.
This is why critics are no good for this type of thing, they don't structure incremental evidence for the operation of each device
as it comes along and before long they don't have a clue as to how these thing could even work. Critics need to stop saying
that there is no theory of operation for this device. It's that *they* don't have one.
No question though, I feel that overloading subsystem functions and variable parametric control structures
like in this device is not genius design but half-*ssed engineering practice. Parameters should have operational
margins not tuning. Variable parameters make it both difficult to understand system operation theory as well as
difficulty bringing it up.
:S:MarkSCoffman
Bravo Mark,  well said.   Your ideas on this device show you have a deep understanding of the unknown or at least untaught principles of energy around us.  Thank you for your sharing these thoughts.
Link to the motor you mentioned:
Technology: High Power Electrostatic Motor - SHINSEI CORPORATION -
And TK     Very Good Advise,  thank you.
IBreal
TinselKoala:
You make valid points about the approach Fix The World is taking.  To improve my chances of posting a 'proceed with caution warning' to others on the QEG Forum I went out of my way to be diplomatic without compromising the points that should be objectively considered about the FTW QEG development thus far and the QEG Forum practices.  This re-enforces the fact that at the QEG Forum you can go out of the way to be thoughtful and reasonable and still be blocked and banned because the QEG Forum moderators are not open to an honest discussion and/or would rather keep their heads in the sand while keeping others there with them.
I've listened to all of James Robitaille's video and audio recordings about the QEG development, he is the only one able to provide technical updates.  I think he was convinced (or scammed) by WITTS and sincerely thinks that he can get the QEG to self run and provide excess power.  He has many years of technical and electronics experience but is out of his area of expertise.  He has openly admitted his failure to self run the QEG at home and admitted the failures he experienced in Taiwan.  He also openly admits that he is still learning and trying to figure out how the QEG works, although at the expense of others.  HopeGirl and some others are cheerleaders with absolutely no technical knowledge, so they are blindly following and are using deception to raise more funds.  Their actions contradict what James Robitaille openly states in technical sessions.  If you read through web sites and listen to broadcasts, HopeGirl and some others would have you believe that they already have a working QEG that self runs and will power a home, which is the opposite of what James Robitaille openly and clearly states.  Bottom line, I was banned from the  QEG Forum for trying to point out what James Robitaille has openly stated.
IBreal
Quote from: F_Brown on April 28, 2014, 11:05:27 PM
I would add to that something that I have yet to see explicitly mentioned anywhere, and that is by all accounts, regardless if the device operates under-unity or over-unity, there is a lethal combinations of voltages and currents present in the device when it is operating.
All would be experimenters should be aware, that they are taking their life in their hands just being within arms reach of the QEG when it's running.
F_Brown:
You make a good point about the need to emphasis the life threatening QEG electrical hazards and TinselKoala provides some good clear examples.  I did not come across discussions about this in the QEG Forum, and it is less likely to be appropriately addressed there as they drive away members with technical knowledge and experience.  In fairness, the QEG User Manual does provide the following safety hazard warnings:
"Electrical / Mechanical devices are inherently dangerous. Electrical shock hazards can cause serious injury and in some cases death. Mechanical hazards can result in dismemberment and in some cases death."
"It is for these reasons that the QEG must be either directly installed or supervised by an experienced electromechanical engineer to ensure the installation is done safely and in accordance with local electrical code, however, the QEG is installed the same way as any commercial generator and does not violate any electrical codes. Anyone who uses the QEG installation instructions (including but not limited to any procedure or method of installation) must first satisfy themselves that neither their safety, nor the safety of the end user, will be endangered over the course of the installation and operation of the QEG."
steeltpu
couple of statements from the QEG people:  "gentlemen arrived from the UK a few days ago with a professional video camera AND very high tech equipment for measuring all aspects of the QEG output and "over unity"
"When all the data has been gathered and tested and measured, and all the information is compiled, and all the instructional videos and recordings etc edited and put together, then everything will be released publicly all at once. Until then, we will be posting updates on all that is happening here, and we will keep you all informed"
seems they should still be given the benefit of the doubt. let 'em show the proof without all the nasty accusations. not suggesting anyone run out and buy parts for this yet. just stop the negative remarkst. if anyone had a clue about the big post Cap-Z-ro made you might begin to understand why that's important. some of the mentally castrated individuals here who think we or they already know everything about everything should take a few lessons from history.
steeltpu
@ibreal   I agree it would be nice to have some ?'s answered and measurements but I think they are trying to avoid killing their funding before they work out the kinks.   looking at the videos of rotaille you see a guy in grubby jeans, tee shirt and unshaved.   doesn't look like someone living high on donations.   looks like a guy busting his butt to get this all working right.   all I'm asking is for people to give it some time before bashing the sh*t out of them.
