0 Members and 95 Guests are viewing this topic.
Hoppy
Quote from: ariovaldo on April 30, 2014, 08:25:57 AM
Check this out....
Even I had the "hope" to find out something new, until now, my generator is very inefficient.
I will do some more tests this weekend.
https://www.youtube.com/watch?v=8x0Zpb67Uw4
Cheers
Ariovaldo
Ariovaldo,
Good looking machine but I could not make out anything you were saying over the noise of the machine running. I could also not see the reading on the meter. If you do post any further videos, please shut off the machine before you speak.
Hoppy
ariovaldo
Quote from: Hoppy on April 30, 2014, 11:36:13 AM
Ariovaldo,
Hoppy
"It's not so easy to teach a new trick for an old horse", but I will try to make a better one in a couple days. Also, the KW-meter positions was not so good.
Making it short, the power consumption was about 1200 watts and the load was not more than 6 x 60 watts lights bulbs. The output voltage in each coil was about 600 volts, but drops with the load. As I said, I'm just testing and is not my intention to make polemics statements.  I'm just an old guy that has as hobby to build and test stuffs..
Independently of the results, is an interesting approach the way that the system works, having the resonance when reach a certain speed. In this case, was about 2800 rpm, but I can bring it down, increasing the capacitance. Also, it is a danger machine, since the voltage is very high in the excitation (high voltage) coils.
Cheers
Ariovaldo
Quote from: Dog-One on April 30, 2014, 05:15:01 AM
Guess I didn't see it, but I will say this, watching this video:
http://www.youtube.com/watch?v=ysIXC1pPQn8
If the stator and rotor have a clearance of 1/1000 of an inch, there is no possible way you can drill holes in plastic with a Dremel tool to get that kind of precision.
They are claiming 1/1000 inch clearance between rotor and stator in THAT p.o.s.? I call bullshit right there. I'll believe they got 10kW Free Energy from a roll of toilet paper, before I'll believe that.
ETA: I am actually _offended_ by that claim, if it is a claim. Go ahead, QEGers, prove to me that that rotating assembly, shaft and bearing set, in the non-metallic mounting attached to a block of wood, has less than 0.0005 inch run-out. Go ahead. Would you like to borrow my dial indicator? What's a dial indicator, you ask? Oh.... never mind.
SIGH.
Paul-R
Quote from: TinselKoala on April 30, 2014, 11:59:02 AM
At what temperature?
Quote from: Paul-R on April 30, 2014, 12:03:23 PM
Toilet paper works best when it's slightly cooler than ambient.
