Marshallin
Quote from: ariovaldo on April 30, 2014, 08:25:57 AM
Check this out....
Even I had the "hope" to find out something new, until now, my generator is very inefficient.
I will do some more tests this weekend.
https://www.youtube.com/watch?v=8x0Zpb67Uw4
Cheers
Ariovaldo
Thx for sharing, good work.
One question:
Doest input power rise when you apply load on generator?
if you put some switch there and test it i will be gratefull :D
ariovaldo
Hoppy
Quote from: ariovaldo on April 30, 2014, 11:52:59 AM
"It's not so easy to teach a new trick for an old horse", but I will try to make a better one in a couple days. Also, the KW-meter positions was not so good.
Making it short, the power consumption was about 1200 watts and the load was not more than 6 x 60 watts lights bulbs. The output voltage in each coil was about 600 volts, but drops with the load. As I said, I'm just testing and is not my intention to make polemics statements.  I'm just an old guy that has as hobby to build and test stuffs..
Independently of the results, is an interesting approach the way that the system works, having the resonance when reach a certain speed. In this case, was about 2800 rpm, but I can bring it down, increasing the capacitance. Also, it is a danger machine, since the voltage is very high in the excitation (high voltage) coils.
Cheers
Ariovaldo
The thing that amazes me about the QEG is how it is intended to run any practical load and stay in a resonant condition. Surely that James chap who designed this realises that the efficiency of a machine working on this principle is totally load dependent and will be very difficult to stay tuned using manual methods. I get the distinct impression from the videos that he has been pulled into something that he is none too confident about and having received so much attention, now feels committed to seeing this project through. He talks rather sheepishly about an output of 2,000V at 10 Amps (20KW) being possible but makes little mention of how impedance matching is to be achieved to actually transfer this amount of power efficiently to a very variable type of load. Anyway, it is a very brave venture and I wish him every success.
Hoppy
gotoluc
Quote from: ariovaldo on April 30, 2014, 12:30:47 PM
This video is almost the same than the other one.....
https://www.youtube.com/watch?v=sli1RCbGs84
Cheers
Ariovaldo
Hello Ariovaldo,
thank you for posting a video of your replication.
Unfortunately the focus is not clear when you show the power meter. Can you please write down in a post the power just before resonance and when resonance lights the bulbs.
I'm also trying to understand what happened at the end when only one bulb lights. Do you know what causes this?
Thank you for sharing
Luc
PiCéd
Excuse me, if I have a primary and a secondary, 10 KWh of electricity and a cos phi of 0,9999, is there theoricaly approximately 20000 jouls of heat in each second if we count the two circuits?
