0 Members and 72 Guests are viewing this topic.
Ariovaldo:
Your replication of the QEG generator setup looks very good.
With no light bulb load, have you measured the motor power consumption when you are at resonance?   If you then slightly increase the motor voltage and the system goes out of resonance, have you measured the motor power consumption?   What about if you slightly decrease the motor voltage and the system goes out of resonance, have you measured the motor power consumption?
Do you know how to measure the electrical power dissipation in the LC resonator when the system is in resonance and there is no load?  If yes, can you make that measurement?  If no, do you want to discuss it first before you make the measurement?
Thanks,
ariovaldo
Quote from: gotoluc on April 30, 2014, 01:24:35 PM
Hello Ariovaldo,
thank you for posting a video of your replication.
Unfortunately the focus is not clear when you show the power meter. Can you please write down in a post the power just before resonance and when resonance lights the bulbs.
I'm also trying to understand what happened at the end when only one bulb lights. Do you know what causes this?
Thank you for sharing
Luc
Yeah, the video is bad...I have a regular job and I just have time at night or weekend and my intention is to do some more tests. About the end, when just one light bulb still on is because when you increase or bring down the speed we lose the resonance and the system starts to pulse and the result is voltage spikes. The others lights bulbs just blew out.
Cheers
Ariovaldo
ariovaldo
Quote from: MileHigh on April 30, 2014, 01:54:51 PM
Ariovaldo:
Thanks,
I will write down everything that you suggested and I will do my best this weekend to test it and put in a table that can be understandable.
Ariovaldo
gotoluc
Quote from: Rfacts on April 30, 2014, 12:26:07 AM
gotoluc (and others interested in QEG audio spectrum):
Thank you Rfacts for taking the time to do the spectrum analysis and post your results.
I think I better understand why they say 400Hz is the resonating frequency. They are speaking of mechanical resonance and not necessarily electrical resonance.
Luc
Ariovaldo,
How are the light bulbs connected to your QEG generator replication?  Can you make and post a schematic of your circuit?   Honestly, we need to see an accurate schematic diagram to explain how only a single light bulb can remain lit.
A proper electronics discussion needs to have a schematic diagram of the circuit under test.
Thanks,
