ACG
Quote from: ariovaldo on April 30, 2014, 08:25:57 AM
Check this out....
Even I had the "hope" to find out something new, until now, my generator is very inefficient.
I will do some more tests this weekend.
https://www.youtube.com/watch?v=8x0Zpb67Uw4
Cheers
Ariovaldo
Nice build.  Do you have the exciter between the output coil and load?
F_Brown
Quote from: ariovaldo on April 30, 2014, 11:52:59 AM
"It's not so easy to teach a new trick for an old horse", but I will try to make a better one in a couple days. Also, the KW-meter positions was not so good.
Making it short, the power consumption was about 1200 watts and the load was not more than 6 x 60 watts lights bulbs. The output voltage in each coil was about 600 volts, but drops with the load. As I said, I'm just testing and is not my intention to make polemics statements.  I'm just an old guy that has as hobby to build and test stuffs..
Independently of the results, is an interesting approach the way that the system works, having the resonance when reach a certain speed. In this case, was about 2800 rpm, but I can bring it down, increasing the capacitance. Also, it is a danger machine, since the voltage is very high in the excitation (high voltage) coils.
Cheers
Ariovaldo
Voltage generating in the system I think is related to drive frequency by the relation d/dt, that the rate of change in the inductance of the system created by the rotor speed vs time.  slowing down the system will lower the output voltage.
I'm very glad to see you have a flywheel on the motor.  I think this will be an important part of the system.  Ultimately, I would like to see the motor, flywheel and CEG all on one shaft for the best efficiency on the mechanical side of things.
ACG
Quote from: Dog-One on April 30, 2014, 05:15:01 AM
Guess I didn't see it, but I will say this, watching this video:
http://www.youtube.com/watch?v=ysIXC1pPQn8
If the stator and rotor have a clearance of 1/1000 of an inch, there is no possible way you can drill holes in plastic with a Dremel tool to get that kind of precision.
Not shown is the very thing for which it is named.  You cannot have a rat trap be effective if there is no rat.
"Ou es le" Quantum exciter coil   ???
Dog-One
Quote from: ACG on April 30, 2014, 02:49:32 PM
Very true.
But if you build it like Mr. Tesla did, it shouldn't need one.
ariovaldo
Quote from: ACG on April 30, 2014, 02:46:59 PM
No...straight from the coil to the load...
