Hoppy
Quote from: ACG on May 01, 2014, 01:34:18 AM
I have yet to see a quantum exciter coil in the Morocco setup.  This is that very thing separating the QEG from any other contemporary generators.
The Morocco QEG may have been pre-primed with the exciter before the video of its operation was filmed.  :-\
I imagine that once everyone has spent out on the expensive kit of parts, or ready built QEG, maybe the next step could be to loan out the special black-box exciter - ambient energy collector - for a couple of weeks to each builder. This would prime each machine for OU operation on the proviso that the operating instructions must be very carefully followed. The loan of this special piece of equipment would presumably be at a cost, maybe a donation to the Hope organisation.
Link to post will be at top: http://be-do.com/index.php/en/forum/qeg-general-topics/323-possible-rotor-construction-in-witts-generator#1296
Can this be confirmed?  Exciter coil is only needed for the first couple of weeks.  I am looking for the audio conference of this statement.  I only see the manual 3-25-2014 instruct to adjust the spark gap every few weeks.
How would that translate into hours?  A weeks time of 5,10,15 hours a day?  The manual where it states the exciter coil is used to conduct power from the quantum zero point into the core and this produces the over unity.  If exciter could be removed then what pray tell what would be the majority of the power production?
Have you seen a quantum exciter coil somewhere else? Please enlighten me.
The only separation happening in the QEG is people being separated from their money.
Does the manual explain just _how_ the Quantum Exciter Coil conducts power from the Quantum Zero Point into the core? Does it even define the Quantum Zero Point? What the heck is a Quantum Zero Point anyway?
There is a real meaning to "zero point energy" but apparently none of these people know what that meaning actually is, and there is no hope whatsoever that WhateverGirl and Robitaille will get anywhere close to conditions that would allow exploitation of it.
Quote from: Hoppy on May 01, 2014, 04:07:05 AM
Insert ROFL here!
How about we wait until Robitaille and WhateverGirl report and demonstrate a self-running machine? Then we can worry about sending them here and there around the world with a special secret Quantum Vibrator to hump-start everyone else's non-self-runners.
MarkE
So far the demonstration tour has failed to demonstrate a working unit.  How much more of this is to go on before people start demanding evidence that they can deliver on their extraordinary claims?
gotoluc
Quote from: TinselKoala on April 30, 2014, 06:33:47 PM
Heh.... 1500 RPM is 25 Hz. 25 x 29 is 725. 500 + 225 is.... 725. Numbers don't lie!
( but they do joke around a lot.)
I know why the numbers don't add up. You have ignored the word range... if you use those numbers it won't add up correctly. I cannot measure my rotor RPM since my test device is in a closed box, so I used approximate numbers and knowing this I added the word range.
One thing I can tell you is my variable frequency drive controller was set at 58.2Hz during the spectrum analysis test. What exact RPM my motor was able to turn the rotor at considering friction losses?  I don't know and not about to open the protective cover to find out when I know my I cores are only holding to the rotor with Epoxy.
Luc
