verpies
Why does the Mutual Inductance depend on the Primary Current ?
F_Brown
Quote from: verpies on May 05, 2014, 10:06:41 AM
The mutual inductance is calculated here as
Secondary Flux / Primary Current
or equivalently,
Primary Flux / Secondary Current
tysb3
Tishatang
I found some info that I think relates to this discussion thread.  This pdf has lots of info re ferro resonance.
http://www.panacea-bocaf.org/files/T...%20and%20D.pdf
Also new for me, is this statement on page 26 about "iron loss" the core loses weight.  Maybe this is the source of the energy, loss of mass converted?
  Quote:
  Resonance is the fundamental base of ZPE energy transformation.
OU is transformation. On an improper heat treated & aged transformer laminate plates at resonance a phenomenon occurs called Iron loss. (Core looses weight) & no one wants to touch the issue with a ten meter pole. Seike reported weight loss in his ferroxplana cores, proper resonance with nature open door to Unforced sea of energy
Maybe someone can forward this info to the QEG team.  Maybe it will help solve some problems?
verpies
Quote from: F_Brown on May 05, 2014, 10:17:23 AM
The mutual inductance is calculated here as  Secondary Flux / Primary Current
But flux does not generate current in inductors.  Only a change in flux does.
PiCéd
In fact it is only the varation of the inductance who produce electricity in coil, the more this variation is the more you get electricity.
An intersting thing is to known what material other than the magnet is capable of diminish or raise the inductance?
