chrisC
@Jimboot
Your info. on Tharpp is incorrect. Just last Wednesday his broadcast interview shows he's still managing the WITTS organization. (#189)  http://www.witts.ws/189/
At about 45 min. into the video, he gets into some details about the FTW QED.
I am more than convinced the Tharpp and FTW device is real and works. There will be confirmations soon.
woopy
Hi all
I took the time to listen to the interview of James at peswiki , and i was puzzled by the fact that the power could come from the physical steel vibration (or resonance) so i made this small experiment.
http://youtu.be/mLK1VG8h2Wc
hope this helps
laurent
Woopy:
That looks like a "microphone" effect.  If there is even a small amount of remnant magnetic field in the core, then that means you have a "moving coil" and a magnet interacting like any other generator coil.
I know others have stated that this may make the magnetic domains in the core's metal lattice change orientation because of the mechanical/acoustic pressure waves in the core when you strike it.  That would also be similar to the above, but this time it would be more of a "moving magnet" and a coil interacting like any other generator coil.  I don't know anything about this effect though.
Perhaps it is the two effects combined.
A real challenge would be to measure the amount of electrical energy in Joules that you get out of the system when you strike it with the piece of stainless steel.  I am not asking you to pursue that, it's more of an intellectual challenge.
gotoluc
Hi Woopy and all,
believe it or not, yesterday I did the same test as you did Woopy. I have many MOTs already cut open, so it was an easy test to do.
I got the same result on the scope as you. Looks like a change in Inductance cause a voltage rise. So, at a fixed rpm and the right capacitance it should bring the tank circuit to resonance.
In a few days I'll make a video of my findings
Luc
