stivep
Quote from: hartiberlin on March 28, 2014, 08:41:55 AM
If you look closely the WITTS Demo by T. Thrapp shows, that the motor does NOT slow down
when the screws in the bulbs... at minute 7:30
This is the best evidence for a fake...the motor speed
should change !
So the bulbs are just powered by the grid and not the unit...
The cameraman also asked this and then see, what Thrapp says and has some
kind of excuses...
Well I did not hear it slow down... and I watched it several times...
At this huge load the motor
should already slow down, when he only screws in 1 light bulb....
Also the QED circuit digramm does not include the dc rectifier bridge, what is
listed in the parts list, so it is probably a wrong circuit diagramm and can´t work this way...
So how would they drive the DC motor with AC then ??
Don´t fall for this scam until they will show their own unit really selfpowered...
Regards, Stefan.
No my friend  Stefan It is NOT the case at this time. You making wrong assumption in regards to power equation. Where  components are brought to your particular envisioned parameters.
You might fight over QED.                                     I'm talking about Russian  guy and  Witts
fluctuation will not happened
if  current produced by the generator is t strong enough  for actual and much stronger load  than the one that is connected to the generator.
The same story is if you switch on in your house, all of the light bulbs instead of one, or regular motor  that is lower in power , than your grid  on demand current.
In  2  motor devices  or motor with balance wheel
Although  the mechanism  of  electric current production  is not much clear and it does not make much sense to  one skilled in science the important is to mention
Perpetual Motion
Every mechanism goes from
-enough  of power  delivery for  motion
to
- enough of power delivery for motion with increased load
to
power delivery= maximum load to be able to  withhold.
than we will see "perpetual motion""(PM)" with the minimum  losses compensated by external energy.
If that energy of 2 motor configuration under the load of 2000W is compensated by any of unknown mechanisms  Perpetual Motion  PM will be sustained.
At that Point  "(PM)" for us will look like PM till the source of energy compensation is found and described.
In one of concepts there is video showing Balance wheel to increase mechanical motion acting  as  energy storage for period of time where there is consumption of energy while waiting for compensation.
Again my  example with  15 of 15 years old girls pushing small  car to speed.
The vector of force is summary of all of 15  girls.  divided by 15= 1/15 per girl.
After a while there is a need  for one girl to  compensate and still accelerate.
After a while there is a need for one finger of the girl to compensate a losses
And acceleration is inversely proportional to the force in time.
I have options:
- to stay with Colman project
- to go back to Lithuania experiment
- to build 2 motor  configuration with or without success.
- to contact the people from Russian area and try convince them or try to buy working device.
so for now I'm staying at the course of Colman and possibly Lithuania Experiment.
So far I'm in access to EDXRF to find accurate and precise periodic table components of any given specimen from Sodium to Uranium.
Scintillators and HPGe portable and  fixed based on LN cooling for  Any decay monitoring and measurement and acquire data  of spectrum in qualitative and quantitative    measurement and high level professional software traceable to the bureau.
That  all above gives me  the tools to see any possible transmutation, or  decay if one is present :) :) in spectrum from X-ray to Gamma as well as particles ( mass)activity as well.
I do not rush.
Not I do, care to be famous or beneficiary of any kind.
And that is me  differing  a lot  from may of  others.
Khwartz
Quote from: Paul-R on May 15, 2014, 12:06:25 PM
It is a matter of definition.
Indeed, like my countryhood philosopher Voltaire used to say (approximate translation): "if you want to discuss with me then define your term so that we could understand each other!".
But definitions have purposes. If we have create this COP in our heat-pump engineering offices, it is to focus on the right target. That why we have other kind of COP caring on financial investment costs and maintenance costs that we have to take in account to know the real performance of the whole system.
Heat pump ARE indeed O.U. but in term of COP, NOT in term of PHYSICAL EFFICIENCY!  And unless you guys you start to make the difference you will stay in confusion about :/
Regards.
centraflow
@ Acca and all
Platinum investments is 20min from me here in Valencia, they are a public floated company and seem to be government backed. Their main business is in industrial waste processing, be it radioactive or typical household waste. They use a system of plasma in a reactor and from the waste produce fuel/energy which is resold again.
I have been trying to have a vist to them to see for myself these generators (they are expensive), but as of yet I have not had a reply to my e-mail, I have heard that scientists are not welcome from one source, so I am not holding my breath, and for sure if I did get an invite it would be without testing equipment.
I must say that I like the hydralic motor idea of driving the generator, this in itself is an energy saver (huge torque for little input).
The batteries I would presume are just to start the hydralic pump until the generator is up to speed.
The generator itself is anyones guess at the moment, though a lot can be seen from the videos and pic's.
regards
Mike 8)
memoryman
"I must say that I like the hydralic motor idea of driving the generator, this in itself is an energy saver (huge torque for little input)." that is incorrect; hydraulics don't save energy. Agood electric motor can get >95% efficiency, better than a hydraulic system.
gravityblock
