Solid State "Synchro Coil".
Started by synchro1, March 31, 2014, 11:02:53 PM
synchro1
@Wings,
Here's some input on two toroidal coils of different radius:
Two coils toroïdales of different radius powered in AC.
Output:
1) Coils 'B' inside the air gap of the coils toroïdales, the form U of these coils allows reducing the effect of the law of Lenz (producing scalar waves? according to Bearden the scalar waves perturb the field of the Aether: therefore this mounting will be more effective).
2) Coils 'A' to the exterior one coils toroïdales, equally for the type coils 'B' these coils allow the passage of current of a direction on a spire and of inverse direction on the other spire, being given that the spires are very near of each one other: the back EMF will be reduced to see annihilated.
A big question remains without response: The currents induced in the coils 'B' and 'A' will they have a tension and an intensity that surpass (Over Unity) those injected in the toroïdales coils?
Such are my reflections on A-Field.
Link to the original Quadra Test:
http://www.rafoeg.de/20,Dokumentenarchiv/30,Wissenswertes/,Gravitationstheorien/Telos_Experiment.pdf
synchro1
On running AC current through the toroids:
"Magnetic induction can occur in a zero curl magnetic vector potential field, as the toroid illustrates.  The only requirement is a time changing field".
Apparently, reversing the direction of the longitudinal wave can cause magnetic induction!
wings
Quote from: synchro1 on April 04, 2014, 12:39:23 PM
@Wings,
Output:
I prefer this document
http://www.reocities.com/Area51/Starship/9201/ortho/ortho.html
but take care if you winding a toroid starting from one point all around up to the same point at the end you have also one virtual single loop coil that induce EM on the torus axis , this why you have to wind a return coil back to the initial point in order to have just vector potential effect .
synchro1
@Wings,
            Very interesting document on "Aether Control" by Rick Andersen!
Here's a quote from you:
"but take care if you winding a toroid starting from one point all around up to the same point at the end you have also one virtual single loop coil that induce EM on the torus axis , this why you have to wind a return coil back to the initial point in order to have just vector potential effect".
Judging from that, it might make more sense to simply wind a bifilar and connect it in series like a Tesla Coil. What do you think?
synchro1
I found this to be of high importance from "Aether Control":
"There's a net direction of "A-field flow" through the center hole of the donut-shaped toroidal coil.
There's a so-called "North" and "South" direction. The A-field's "lines of potential" flow into the center hole on one side, concentrate there, then flow out on the other side and broaden out into larger loops that eventually converge back into the coil. So, although the magnetic (B) field of a toroid is circular in shape and contained almost entirely inside the toroid itself, the magnetic vector potential (A-field) is TOROIDAL in shape, like an enlarged version of the coil itself-- and composed of, presumably, toroidal loops of aether itself, in a preferred direction through the toroid"!
The toroid projects the magnetic "A" field vector potential in a specific direction through the center of the toroid!
Start viewing this video at 2:57; I was powering the neo sphere with the toroid spiral coil. It shot out like a cannon ball!
http://www.youtube.com/watch?v=9XMfCpUzq_g
