Thanks to ALL for your help!!
How to smoke Lorentz
Started by dieter, April 04, 2014, 05:01:35 PM
dieter
EDIT: PLEASE READ FIRST! :
Even if this is emberassing for me, I tell you this right now, so you will not waste time in trying to replicate this: It turned out it is the microwave oven magnet that causes the effect. It works also with other iron objects, not only with coils. These magnets must be magnetized asymmetrically. The bloch wall is not in the middle. There is this imbalance, but since after all it's just a PM, I am afraid that the forces will equalize somehow.
So I was wrong. Once again, the quest continues.
Here follows the original posting...
Hello everybody, I think I just smoked Lorentz, and probably half of Lenz as well.
By smoking, I meant not litarly, but more figuratively, in finding a way to neutralize the Lorentz force. In other words, I may have just found a key to free energy.
I may investigate on this in detail, but right now I want the let you know the basics quickly.
Recently I discovered that an iron coil was attracted more to the north pole of a magnet than to the south pole. I did this experiment with care and it is a fact. Most amazing find is: If I turn the coil 180 degrees, then it will not reverse this feature, but remain exactly the same.
As somebody who is into magnetism quite a bit, you should just think about this for a moment. That means, when the iron is on eg. the left side of the PM then it will be attracted strongly and, assuming some rotor, swing by. When the bloch walls have crossed, it will be attracted less and keep on rotating. You know how this continues. Just like a pulse motor. This is... wow!
Furthermore, when we use a iron coil as an induced generator coil, then the induced current will cause a bfield trough that iron coil, that can neutralize the lorentz force, that is normally braking the rotor. The more current flows in the induced, the higher the lorentz force, but in case of the iron coil also the more lorentz-neutralizing electromagnet force of the coil.
Lorentz successfully smoked. Quad erat demonstrandum.
EDIT. actually, not shure about the second part, that would be possible with copper too, so... But part 1 is still  standing. Guess there must be ways to use this in solid state...
Any potential invention in this posting is hereby declared public domain.
Magluvin
I think Leedskalnin said he was able to do more with iron than copper.
Nice work.   ;)   Any vids?
Mags
MarkE
Quote from: dieter on April 04, 2014, 05:01:35 PM
You've discovered remnant magnetization.  Lorentz is alive and well.
dieter
Magluvin,
thanks. vids hopefully soon.
MarkE,
remanent magnetism isn't monopolar. But I will have to do further tests to verify what's going on. I am pretty shure it's not remanent magnetisation.
EDIT: please read post 1 again..
MarkE
Quote from: dieter on April 05, 2014, 12:10:41 AM
Magluvin,
MarkE,
Neither are your iron wires.
