3v OU Flashlight
Started by 4Tesla, April 14, 2014, 02:55:28 PM
0 Members and 31 Guests are viewing this topic.
tysb3
@hartiberlin
this is information is from Akula. ant I think you are wrong, sorry. Akula have OU device  and you don't :)
sorry for my English grammar.
tysb3
@hartiberlin
you don't understand. you don't need HF generator to work on the cores resonance frequency. it's need to work on the lower harmonic of this resonance. but fronts of  the signals need to be possible vertical. because of this transistors and diodes need to be possible highest frequency.
and I think you need 2 resonances: (1)HF coils resonance (to minimize amps from power suply much as possibly)  on lower cores frequency and  (2)cores resonance (for OU)
hartiberlin
You can actually hear the resonance in his circuit and it is probably such
a dimensional resonance as it is spoken in this Ferrite core PDF file that was just posted..
I just read it.
TK also has such a MnZi core with its low resistance of 50 Ohms/1cm.
These also have these dimensional resonance effects, so the core
is probably right...
Well, maybe you can tell us exactly what Akula said in this Online session ?
in the used circuit, which is a really strange switching circuit
http://www.overunity.com/14524/3v-ou-flashlight/dlattach/attach/137522/
the lower sine frequency comes probably from the secondary coil with the 100 uF
as LC tank which pulls down the supply voltage via the Q3 MOSFET and thus
switching on and off the DC2DC converter chip MC34063.
Maybe he made an error and wanted to have the the DC2DC chip running
all the time...
As the ferrite core rings at around 8 Khz probably the spike frequency is around
this 8 Khz frequency with this low sine wave modulation or better said chopping it...
In this video he shows the scope shots:
https://www.youtube.com/watch?v=Lpx1SJdXnmo
I wonder why TK does not have the underlayed sine wave, where the spikes occur on the yellow channel....
Maybe he must avoid full dimensional resonance that shatters the core sooner or later ??
So he tries to change the spike frequency around the resonance frequency like a FM modulation ?
Regards, Stefan.
dewetw
Hi everyone,
it is my first time posting and may I add it is a lovely sunny day in South Africa. I have been doing research into alternative energy devices for a few months now and thought it was time to share/help.
There are several ways of getting energy "from no where", BUT lets not skip over this 'no where' just to see something MAYBE working by poking in the dark. Lets look at the concepts behind what is happening and then develop it from there. First of all: What are we really after? Answ: control of electron flow. Before we can make electrons flow we need to find the best source where we can trade or trick to get some.
We know nature have tons of "misplaced/free roaming" electrons and when they get together we see things like lighting and static discharge - so NO question that it is there for the taking. Where are do these electrons hiding when not being conducting to earth? Short answ: the ionosphere. Think this way: give the electrons in the ionosphere a reason/pathway to flow into the earth and then put your load in series with that pathway. What do you think would happen? Sounds like the Tesla/Kapanadze devices?
BUT this is only one way of doing things AND you can combine methods to achieve the desired end result. NOW onto the method used or being searched for in this thread.
We need a source of electrons. We know metals have "loosely bonded" electrons - this is why they conduct electricity (they are willing to swap out electrons if pushed to do so). We also know metals are willing to give up electrons in exchange processes - we call these batteries , where by chemical or molecular bonding "swop outs" we can harvest electrons. SO we know there is energy in metals.
What if there is ANOTHER way of getting the electrons from metal? THERE IS! Science call it Nuclear Magnetic Resonance (NMR) and it is used in NMR Spectroscopy equipment all the time - once again we thus know it exist and is possible. NMR uses the principal that specific elements vibrate/resonate at specific frequencies. At these frequencies they "give off" or radiate electrons - this is how you identify what molecular elements you are testing in your spectroscope. Because it is SO specific it is easy to miss. DON'T GIVE UP AFTER 10 MINUTES OF TRYING!!! It is a needle in a haystack.
HOWEVER, the plot thickens. Electrons have WEIGHT - take a high voltage, high frequency source, connect a thin enamel wire to each end, place the other ends of the two wires close to each other to create a spark gap or plasma discharge space, offset these ends such that they are not aligned. Now you have been taught that electricity always takes the shortest path, right? What you will find is that it does not jump straight from the one end to the other, it flows in an S-shape. Why is this? Well, the electrons are "running" down the wire at high speed. As they reach the end of the wire their momentum forces them to continue straight UNTIL the pull of the potential difference sway them in another direction and an electron "wind" path is created. This is proof of the fiscal weight of electrons.
THE  PUNCH LINE OR TRICK:
If we can make electrons "spin" in a certain direction and then move away the molecule that electron belongs to quick enough then, at least for a moment, that electron will remain spinning in its location due to the torque of spinning weight and therefore it will be free roaming - now give it a path to conduct to somewhere else and place your load in series with that path.
How do we move the molecule away fast enough? Short answer: Nuclear Acoustic Resonance (NAR). This happens when the fiscal structure containing the molecules starts to vibrate at IT's (structure) specific resonance. It is clear from the experimenting and devices/circuits being constructed in this forum, in this thread that you are close. BUT remember it is a needle in a haystack - finding it is not easy, but it IS possible.
SUMMERY:
Achieve NMR perpendicular to NAR and create a conducting path (with your load in series) for the free roaming electrons. HOW: A ferrite core is a structure that contains metal that can vibrate/resonate fiscally and it contains loosely spinning electrons that can be spun in a certain direction by applying a magnetic field of the right strength.
It should be noted that these devices will not last forever, BUT they are a gazilion times better than any known battery process. Now you have concrete known processes to follow and use to achieve electron harvesting. Hope I have helped you out of the darkness  :)
The capetonian
tysb3
@ all
I'm very sorry for my mistake. ferrite cores resonance is in Mhz range, not in Ghz. It's to be right 1 - 3,5 Mhz
