3v OU Flashlight
Started by 4Tesla, April 14, 2014, 02:55:28 PM
dewetw
@lost_bro
You should change your name to found_bro. You are on the right path and have posted all the relevant information regarding torque of electron spin in the material and the accompanying magnetostrictive effect. PLEASE TELL ME YOU ARE BUILDING CIRCUITS ALREADY??? We used the magnetostrictive effect of pure nickel tubes back in 2003 to do simultaneous multi-level sensing of the throth separation tanks at Anglo gold and platinum mining in South Africa. Nickel has a far superior ferro movement vs iron or other obtainable metals.
For better performance the nickel tubes was annealing (basically heated, current applied to it to align electron spin and cooled in this way). This permanently changed the properties of the material itself and much less energy is needed to achieve the magnetostrictive effect (which is the return energy that get induced back into the receiving coil). Since the electron spin is now aligned there is no need to pulse a driver coil to do this just to break it (spin direction) up again and repeat - you can imagine the energy saving.
Your core should have the highest possible amount of nickel in it and electron spin annealed in a fixed position.
The capetonian
MenofFather
Quote from: TinselKoala on April 30, 2014, 03:18:37 PM
So let me get this straight. I am using Akula's circuit with only two substitutions: A TIP3055 that switches, instead of a mosfet that doesn't switch, and a 100R resistor in series with the two LEDs on the cathode end to ground.
I've corrected the seeming errors in the inductances stated on the original schematic and I've found that the inductances were likely reversed in the original schematic somehow. After much effort tuning and fiddling and substituting, winding several different coils and exploring the problem space nearly full time over the last three or four days... and I have actually reproduced, as far as I can tell, the exact waveforms that Akula is exhibiting. Frequency, amplitude, envelope, harmonics, noise... it is all there. I am less than 5 percent off in any direction.
Yet many of you are telling me I need some other ferrite material.  Even though I have the exact same waveforms.
PLEASE EXPLAIN in actual terms that have meaning, with references to checkable credible sources, how this can possibly be.
It certainly seems to me that if I had different material that resonated at a different frequency I would not have these waveforms using these component values. Anyone care to challenge this, perhaps with _a demonstration of your own_?
If this words to me, then let me see you drawed schematic. And I nothing say, that you core is from not good material.
MenofFather
Quote from: TinselKoala on April 30, 2014, 03:30:05 PM
I have 510 picoFarads.
Current schematic:
http://www.overunity.com/14524/3v-ou-flashlight/dlattach/attach/137847/image//
So you can not replicate this schematic? If you say, that it is exatly like Vadim schematic, then it is not exatly like Vadim, here many diferences, inductance not that addadet resistors and so on. If you replicating Akula divice with pot core, here also not exatly like in him, because he in video say, that other generator not used, but you using two generators, he use ony one.
magpwr
Quote from: TinselKoala on April 30, 2014, 10:39:48 PM
In the closeup below you can see the three elevated pads for the LEDs. The black cylinder is the 1000 uF cap, its negative lead is soldered to the ground plane and the red wire is its positive lead, going to the Anode pad of the Blue LED. The Cathode pad of the White LED is connected to the 220R which is then connected to the ground plane. So I got the wiring right but the schematic insert wrong.
I tried the 220R but I think I'll go back to the 100R.
hi TinselKoala,
It's afternoon over here.
I took a look at the circuit once more.
I do find there is no recovery at all from higher voltage potential found across 1000uf capacitor and back to the MC34063 in order to create a self run.
It looks like-The higher potential is merely used to power 2 led in series besides charging 1000uf capacitor and also serve as voltage reference for P1 base on current circuit layout.
Can you try to see if there is any drop in input current after connecting wire(temporary) from output of D1 to MC34063 pin7.
Do try to connect battery or 3v power source few times to circuit -Akula style as seen in video for 2nd experiment after connecting temp wire as well.
Did you ever notice any hint of "overunity" performance in your annealed nickel tubes?
I should think that the scientists that could figure out how to use magnetostriction in a flow process at a gold mine could figure that out too. There is more "gold" in an overunity process than there is in the mines of South Africa, and if you believe Akula it's a lot easier to get to, as well.
Electron spin resonance is a far cry from NMR even though some of the same principles are at play.
Where is the spin-polarized annealed nickel in Akula's 3v flashlight, though? I must have missed it....
