3v OU Flashlight
Started by 4Tesla, April 14, 2014, 02:55:28 PM
0 Members and 39 Guests are viewing this topic.
verpies
Quote from: T-1000 on April 17, 2014, 07:01:34 AM
Here is excerpt from patent application for all this stuff:
So the bottom winding is split into two parts and the top winding is not.
So that makes 3 coils total and the text confirms that in the 1st sentence: "три катушки" = 3 coils.
Is this Russian text translated into English somewhere?
T-1000
Quote from: verpies on April 17, 2014, 07:20:33 AM
So that makes 3 coils and the text states that in the 1st sentence: "три катушки" = 3 coils.
There is no English translation yet.
Also due 3 topics on 2 different forums I am not sure if here it is best to drop in more information about it but I will try. :)
Delamorto/Akula LEDs flashlights circuits are following that patent application too.
Probably everyone remember self runner circuit - https://www.youtube.com/watch?v=Du8_moSa7KY
It is real manifestation of what was in patent application.
Here is its top circuit diagram of circuit in that video:
magpwr
Quote from: MenofFather on April 17, 2014, 02:23:31 AM
I will try with other windings. one coil 25 about turns, other, 60, maybe turns. Then I regulate inverter potiontiometer, then generaly nothing change, I in series conect miliampermeter and curent practicaly is stable in any position of potiotiometer.
Я ещё несколько раз перемотал катушку, медные ленты не использовал. И меняя какбы напряжение, ток никак не меняеться потребляемый от крутения того резистора, который Вадик крутит на видео, у меня его можно крутить в широких пределах и всё остаёться то само, только в одну сторону закрутив там что-то падает или растёт, но это потому что, видемо, прекращаеться режим инвертера и тоже ничего явного нет, чтоб очень сильно ток упал. У меня сердечник Ш образный.
hi MenoFather,
Have you try to swap only one of the winding be it primary or secondary side to solve the issue and measure current consumption again during tuning.
It can be a common mistake normally made on self-made transformer with 4 wires(2 pri, 2 secondary).If connected wrongly the circuit will never oscillate.
By observing video 4 you can almost hear the  ticking noise base on slower frequency signal produced by I/C:4069.Do use this frequency of ticking sound as a guide for your circuit.
Have you look into the counter poise beneath the Ferrite core on the copper track which looks near to a square shape(-).
MenofFather
Quote from: magpwr on April 17, 2014, 12:22:00 PM
hi MenoFather,
I can't confirm if this do plays a part-----------------------
I observe the copper\brass screw thread is soldered onto large copper track(square shaped).
Do observe the screw at the center of pot core  is metallic instead of plastic.The top half is nicely insulated using the "plastic insulator" with the metallic screw going through it which is also similar shaped for TO-247 heat-sink insulator\mounting kit
Last my version have E core. I try with aliuminum tape conected to first wounded wire and try change position of wires, this nothing change. Now  burn 34063 and power sonsumption is about 10-20 miliamperes from 6 volts. Green light flasing. I not have pod core. I then not be burned 34063 have power consumption about 2,5 volts and 200 miliamps and nothing helped to me to make smaller cunsumtion strongly.
Thanks for advice. ;)
semenihin-77
Ошибка всех получать автономную работу сразу, на 1 видео у меня не было ключа на возврат энергии, получать нужно импульсы с "фонарик видео 1", их настраивают напряжением питания. Вот когда вы их увидите на осциллографе 1-4 вывод 34063, тогда надо настраивать коммутатор, а до тех пор отключите коммутатор.
Error getting all autonomous work immediately on one video I did not have a key to the return of energy, you need to get pulses with "фонарик видео 1", set up their supply voltage. That's when you'll see them on the oscilloscope output 1-4 34063, then you must configure the switch, but until then disconnect switch.
