3v OU Flashlight
Started by 4Tesla, April 14, 2014, 02:55:28 PM
0 Members and 18 Guests are viewing this topic.
rakarskiy
Quote from: Sergh on September 07, 2019, 02:33:51 AM
This simple formula will not give any free energy.
Large magnetic permeability allows you to push 1 times more energy through a smaller cross section of the magnetic circuit.
The energy from this does not increase. The best transformers in the world work with efficiency below 100%.
https://en.wikipedia.org/wiki/Electromagnetic_induction
Transformers work on the effect of mutual induction, more than introduced, it is impossible to take.  Do you know the difference between mutual induction and induction? And the magnetic field in the core is really N times greater. And this formula is unacceptable for a transformer.
The operation of my circuit is based on the delay, reverse magnetic hysteresis. And the "spring" magnetic field in the abutment, the better.
Да, привет Челябинскому Региону! Мое предложение сутки пока в силе!
Sergh
1. A static magnetic field does not produce energy.
2. A person, who changes the magnetic field, requires food for this.
;D
"Free" energy from small hidden battery - enough for 1 year:
https://quickjewelryrepairs.com/wp-content/uploads/2018/02/WatchBattery.jpg
rakarskiy
Quote from: Sergh on September 07, 2019, 08:16:10 AM
2. A person who changes the magnetic field requires food for this. ;D
Here I with you agree, there is no movement there is no EMF (potential difference electric tensions). But you probably do not know what a cost-free Controlled Reverse hysteresis of the magnetic field, with periodic unipolar excitation of this field.
http://hyperphysics.phy-astr.gsu.edu/hbase/Solids/ferro.html
http://hyperphysics.phy-astr.gsu.edu/hbase/Tables/magprop.html#c2
http://hyperphysics.phy-astr.gsu.edu/hbase/Solids/hyst.html#c2
There is nothing that is not known to classical physics, here is an engineering solution that is what is valuable for technology. Traditionalism is not always the truth.
Reiyuki
Quote from: rakarskiy on September 06, 2019, 10:03:13 AM
No point arguing, "everyone has a right to their own rake"! FORMULA OF MAGNETIC INDUCTION FOR THE CORE OF THE SOLENOID: Only (Mu0) need to write like (Mu * Mu0)
Where
       N- is the number of turns of the solenoid
       l - long solenoid
      n - number of turns per unit length
      I - Current in the solenoid
       Mu - magnetic permeability of the medium inside the solenoid
      Mu0 - magnetic constant
The formula can work if permeability is varied with respect to time.
rakarskiy
Quote from: Reiyuki on September 07, 2019, 10:43:54 AM
The smooth cascading of the magnetization to ZERO.  If this problem is solved, efficiency > 1
It is only with the material needed magnetic memory.
