Sun focus hydro turbine.
Started by DaS Energy, April 21, 2014, 09:56:32 AM
DaS Energy
Parts need. Three swing valves, one floating ball. One hydro turbine. One Solar focus.
Workings. Heated air rises to the surface of the water providing it downward movement. The water movement passes through the hydro turbine and compresses air into the holding tank.
Air movement into the longer cylinder trips open the air release valve which remains open until the cylinder is again full of water.
The lack of moving parts, and near zero friction losses makes this the most efficient of any solar heated air engine.
s3370389
QuoteHeated air rises to the surface of the water providing it downward movement.
Can you elaborate a bit on this, please? I am not really understanding your diagram.
QuoteThe water movement passes through the hydro turbine and compresses air into the holding tank.
I don't think that this will work. The pressure in the holding tank might rise slightly, but when it does you will need a hell of a lot of heat to increase it any further. Why will the water be moving? Buoyancy from the heating effect? Surely this will not cause enough convection to turn the turbine in any significant way?
QuoteThe lack of moving parts, and near zero friction losses makes this the most efficient of any solar heated air engine.
I'm not sure about near zero. What about frictional losses from the turbine? What about shear stresses, viscous friction, of the surfaces that the water is moving against?
DaS Energy
"might rise slightly"
Might not!
MarkE
Maybe I am not seeing the whole picture here, but what prevents the collected heat from heating both the water as shown and the air all the way back to the turbine, thereby working against it?
DaS Energy
MarkE
Hero Member
Re: Sun focus hydro turbine.
« Reply #3 on: July 20, 2014, 03:26:24 PM »
You be correct the heated air does heat the water. You be wrong no heated air goes back to the turbine.
