The Bessler Wheel, mystery solved.
Started by gurangax, April 24, 2014, 02:40:13 PM
gurangax
Quote from: zoelra on April 27, 2014, 12:20:36 PM
gurangax said
You said lever not levers, so I have to ask if this unknown behavior or property exists only when two levers are combined into the "two stage" lever configuration you mentioned?
you only need one lever to achieve the effect I am reffering to.
regards
gurangax
There are several versions on the internet of the Apologia Poetica. But one struck me as it closely describe this lever. Thus It shows even more that it is his secret mechanism. Here it is
"Children play with heavy clubs among the broken columns."
Some variation of the poem omit the broken column so it loses some important values.
regards
zoelra
gurangax said
Quoteyou only need one lever to achieve the effect I am refering to.
When you talk of a lever I still think you are referring to some type of multi-bar linkage (like the two stage lever).  When I think of a lever I think of a single straight bar with a fulcrum.  It is difficult to follow each other when we may have different views on the simple things like the definition of a lever.  Can you help clear this up.
gurangax
Quote from: zoelra on April 27, 2014, 01:38:43 PM
I know what a lever is and what a 2 stage lever is. And i literally mean only 1 lever. There is a property not known by many. Maybe if you play with it many times will you notice of this. Its hardly noticed because it were never used like this.
regards
ARTMOSART
Quote from: gurangax on April 27, 2014, 12:57:23 PM
regards
hi gurangax
just 2 questions
das the center of gravity of the lever need to be displaced to alow some work
I supose thas this displacement force must be balanced whith opposite one
thanks in advence
and sorry for my bad writing
artmos
