The Bessler Wheel, mystery solved.
Started by gurangax, April 24, 2014, 02:40:13 PM
ARMCORTEX
Try this thought Tomas.
If you had a hinged motor and a staticnheavy flywheel on a main frame. Double shafted motor,or 2 motors. On hinges, attached by its frame which is rotating, and on the same center point Of the motor orbir the shaft is driving a gear via pulleys, and this is stepped up to high rpm on another axle
Via pulleys again, wich drives a grippy heavy wheel that discharges itself on a static arc held to the floor
The motor recharges the system. The motor is inside the imaginary big circle, the heavy wheel on the edge of the imaginary.
The only tricky thing is the wiring. And they are many ideas here that can aid.
This is the concept.
gurangax
@Tomasz
nice try again, but that wont work.
now I will shed some more lights into the secret, it lays on Bessler word here
"all the inmost parts, and the perpetual-motion structures, retain the power of free movement, as I've been saying since 1712."
I already gave it but no one cared to ask, the meaning of his words. Now I will say this, at one point there is no connectedness of the actuator to the reseter. it is free to move.
regards
ARMCORTEX
Gurangax stop trying to mislead others, you are nothing but a disinformant, I have already given the answer above.
Your mind is not able to comprehend, so you will continue to act as a sycophant
gurangax
Quote from: ARMCORTEX on May 17, 2014, 10:12:21 PM
this is my thread, stop filling it with your design go make your own thread instead.
regards
ARMCORTEX
You can't make me. This is the Internet scumbag.
