The Bessler Wheel, mystery solved.
Started by gurangax, April 24, 2014, 02:40:13 PM
I am now calling time.
It has been a solid seven days since the deadline for the wager has come and gone. Gurangax has had ample time to protest, appeal, demonstrate, etc. but has remained silent. He has not honored the terms of the wager to which he specifically agreed.  He failed to produce the demonstration of a working Bessler wheel and he failed to make and prove the 100 dollar donation that was specified and agreed to well over a month ago.
Gurangax is officially demonstrated to be a deadbeat: someone who makes false claims, insults his critics and who does not honor his agreed-upon obligations.
And I am not at all surprised.
AquariuZ
If I may come to the defense of the Gurangax simple but elegant idea.
I have taken HIS model - simplified it and now show a 3 : 1 ratio lift AND hold of a weight towards the wheel perimeter. I have also added some comments to the model (attached) which are:
I can imagine a large wheel with crossbars like the one pictured on the left and the crossbar weights on the perimeter of the wheel were the pendulums are close to but do not  touch the outer perimeter.
Gravity pulls the pendulums which pushes and holds the crossbars weights towards the wheel perimeter long enough to create an imbalance which will make the wheel rotate.
It will rotate either way and it will be permanently unbalanced. The correctly positioned pendulum lever will give a 3:1 lift ratio. Tuning needed for desired RPM.
Definitely worth a try.
200% weight leverage is nothing to joke about. Look at the potential energy readings in the model. Yes, there be friction mateys, but still worth a try.
Thank you very much Gurangax for publishing this - very interesting. I would advise contacting Preston Stroud if you would like a good builder on your team.
AZ
AquariuZ
Forgot to mention a second (lever?) mechanism is needed to hold the crossbar weights towards the center of the wheel from about 4  to 8 o'clock positions.
I'll try and make a full model.... It will not be easy. (curved slots)
AZ
AquariuZ
Ok real quick.
Try one:
Two lever pendulums of 1.5 KG each pushing a 9KG weight towards the perimeter at the 12, 1, 2  and 6, 7, 8 o'clock positions. Probably more weight is needed in the lever pendulums - but it will not exceed 2:1.
the pendulums cannot detach from the crossbar weight.
the crossbar weight slides radially back and forth
only two crossbar weights needed for continuous motion?
AZ
Model attached
PS: I have no idea how to project this onto a wheel in Working Model. Help appreciated.
PPS: Look at the Gravitational potential energy ratios!!!
LibreEnergia
Quote from: AquariuZ on June 08, 2014, 06:54:17 PM
AZ
It's not worth even trying.
The closest any wheel can become to being "over-unity" is when it is perfectly balanced with a bearing of the lowest possible friction and spinning in a vacuum..
Obviously this configuration is NOT over-unity, but one thing is certain, any other configuration that involves moving weights around during a cycle will be less efficient.
Creating an overbalanced condition requires energy. At best we can recover the some but not all of that energy as the wheel rotates. Since all movement involves frictional losses we would improve efficiency by having less movement of parts relative to each other. Take this to the logical conclusion and you end up back at the perfectly balanced wheel.
